Question about Polaroid A500 Digital Camera
Is there a small battery somewhere that keeps track of the date and time? Every time you turn off and then turn on the camera, you have to reset the date?
3 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: polaroid a520 will not keep the date
You may want to set the factory defaults by going into the main maenu.
Posted on Nov 22, 2009
  • 11967 Answers
SOURCE: How do I keep the date correct?? It alway pops up
Next time you finish setting it, press the set/ok button twice.
Posted on Apr 01, 2010
When the camera is turned on the date/time window shows. If we set the date/time, the next time we have to do it again.
Some cameras have a small coin cell battery that keeps the time and date correct when the camera is off or while changing batteries. You may need to replace that battery.
Dec 18, 2016 | Cameras
Date/Time resets every time i turn on camera.
Hi, yes, there is a small coin memory battery, usually something like a CR3032 lithium battery. Turn off the camera and insert a new 'coin' battery (correct side up). Close battery cover, turn on camera and go to menu and set time and date. It should remember the time and date for a year or two, provided you put a regular battery on the camera on a regular basis. Also note, some older Sony cameras allow you to set it so that it shows only the date for the 1st 5 seconds when you first turn on the camera that day, then shuts it off unless you want it to superimpose the time and date on the video. Good luck, and let me know if this solves your problem. John
Jan 17, 2012 | Sony Handycam HDR-XR520 High Definition...
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
The Canon Powersht A470 has a small button battery
This is the date battery. Ir remembers the date and time when you remove the AA batteries so you don't have to reset the date/time each time you replace the main batteries. Check page 159 in the manual (or somewhere around there) for information. The battery type is CR1220 (a fairly standard type), and should be available at electronic stores.
Nov 09, 2009 | Canon Cameras
Flash setting doesn't work
Does your camera gave a small battery in place somewhere that is used to maintain the date and time settings? (it is generally a watch battery type small flat silver disk.) You should not have to reset time and date after each battery change.
Many digital cameras eat up batteries quickly, especially when using the flash alot., that is why it is important to use good quality rechargeables whenever possible.
Jun 19, 2009 | Fuji FinePix 3800 Digital Camera
I have to set the date/time every time I turn on my Canon A720. Once I've set the date/time, it stays set until I turn the camera off.
YOUR PROBLEM SHOULD BE OVER! ON THE BOTTOM OF YOUR CAMERA IN THE COMPARTMENT WHERE THE TWO BATTERIES GO IS A SMALL DOOR. THIS IS THE CLOCK BATTERY DOOR! YOUR CLOCK BATTERY MUST BE DEAD OR MOSTLY DEAD. AT LEAST IT IS WORTH CHECKING OUT. THIS IS THE MOST LIKELY CAUSE OF TIME DATE FAILURE BECAUSE IT WILL RUN WITH THE MAIN BATTERY POWER WHEN THE CAMERA IS ON, BUT WHEN YOU TURN IT OFF, THIS SMALL BATTERY IS SUPPOSED TO KEEP THE TIME, DATE CURRENT IN THE OFF MODE AND IT IS DOING IT! CHECK IT OUT AND SEE IF THIS DOESN'T SOLVE YOUR PROBLEM. GOOD LUCK! HOPE THIS WORKS FOR YOU!!
ARCLIGHT1217
Nov 08, 2008 | Canon Cameras
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Having to reset date and time
Solution: Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution_a70.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids could damage the stomach or intestinal wall.
  1. Confirm that the camera is turned off.
  2. Open the terminal cover and use your finger nail to pull out the battery holder.
  3. Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
  4. Insert a new battery with the ( ) side facing up.
  5. Replace the battery holder back and close the terminal cover.
  6. When the Date/Time menu appears, set the date and time.
note_icon_a70.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your country.
Dec 24, 2007 | Canon PowerShot A520 Digital Camera
Date time setting does not program
There is not an option to remember the date/time when you power off the camera. The camera should always remember the time. If it forgets the setting when you power it off then your backup battery has gone dead. Check your manual to see if it is something you can replace yourself. I am not familiar with this camera specifically but some cameras make the backup battery accessible and some require disassembly. David Millier Advance Camera Repair
Feb 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Polaroid A500 Digital Camera Logo
29 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
