Question about Maxi-Cosi Priori
The yellow anchor points that attach to the car fittings and then the isofix base fits on to them. where can I get 2 more
  • 419 Answers
If you mean the plastic caps that click onto the isofix points in the car, then you can buy these on eBay, just search for ISOFIX GUIDERS.
I hope this helps.
Posted on Oct 12, 2009
Why is the bottom of the isofix base is not level with the seat?
Hi Andrew
It is not possible to diagnose without inspection.
Was the unit approved for use in your vehicle on our online fitting list?
Was the unit physically fitted by a carseat fitter trained member of staff to confirm suitability prior to purchase?
Please contact us with further information so that we can best assist.
Dorel UK Customer Service
May 11, 2014 | Maxi-Cosi Familyfix Base Isofix only
Need to know where anchor points are in 1989 Mitsubishi Starwagon or do I need install them
Hi
In a 1989 model vehicle it is unlikely that there will be integral anchor points such as IsoFix. You should contact Mitsubishi to discuss with them whether there are anchor points available in this vehicle or whether they can be retro fitted. Please note in order to meet standard for installing an IsoFix or similar fitted carseat the anchor points must be installed by the vehicle manufacturer.
Jul 14, 2013 | Baby Gear
How to remove the isofix base from the car seat
Hi
Is it removing the carseat from the base or removing the base from the car that you're having difficulties with?
Feb 03, 2013 | Maxi-Cosi Familyfix Base Isofix only
Hi, I just installed the isofix base Maxi cosy isofix without the yellow adapter. Know I am worried this could be a problem without using the, Does all users have these on? Is it necessary?
Hi - The yellow plastic guides are only for your conveniance if you need them. Some cars have very prominant IsoFix points and you do not need to use the guides - this is fine. As long as the indicators go green to show correct fitting it is fine.
Sep 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Can the isofix easyfix base be used safely without the isofix guides, ours are missing, thanks.
Good Afternoon
The yellow plastic IsoFix guides are for assistance only when fitting the unit and make no difference to the performance. If you are able to fit the base so the indicators go green it is fine to continue using without the guides. Alternatively if you need replacement guides they can be ordered via your retailer or direct from our customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Sep 10, 2011 | Maxi-Cosi Priori
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
Where are the fittings or anchor points for childseat restraint ... 1993 Mazda 323 · I can't find a child restraint anchor point. ...
It may be that you do not have these anchorage points ( I beleive that you mean the Isofix Points???) If you sit in the seat itself and place your fingers inbetween the cushion that you are sitting on and the back cushion (either side of your hips) You should then feel a metal horizontal bar, about an inch long,
On some models (usually BMW) these Isofix Points are located behind black plastic caps at the bottom of the seats.
I hope this helps
Jul 16, 2009 | Baby Gear
Fitting an isofix car seat in a ford cmax 57 plate tdi
if there are a small part of the backseat (ca 10 cm high located at the bottom of the back) that can be picked out, you have isofix points.
if your backseats are in one pice, theres not
Apr 11, 2009 | 2007 Ford Focus (3 Door) Hatchback
Maxi-Cosi Priori Logo
282 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
