Question about Samsung L200 Digital Camera
The lenses in my l100 will not go back in - Samsung L200 Digital Camera
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I have a Nikon L100 and lost my manual. I can't
    format the memory cards after you back it up. if that doesn't work, try another brand.
    Nov 19, 2009 | Nikon COOLPIX L100 Digital Camera
    My camera won't work!!
    find a re-set button or try taking the batter out completely then putting it back in. contact the website of the company they usually have solutions for such, if this does not help then let me know again and give me the model and make...good luck
    Jul 19, 2009 | Samsung L100 Digital Camera
    Model l100 lens won't retract ,just beeps when powering on
    while viewing stored photos screen goes blankand camera startup lamp keeps flashing.model samsungl100 8.2mp.
    Jul 04, 2009 | Samsung Cameras
    Samsung L100 Digital Camera Problem
    right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
    Oct 27, 2008 | Samsung L100 Digital Camera
    CD player won't play disk and says "no disk"
    The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
    Jun 18, 2008 | Teac CD-P1250 CD Player
    Samsung L200 Digital Camera Logo
    70 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
