Question about Frigidaire Dryers
My Frigidaire Gallery Gas Dryer is not heating anymore. What could it be?
  • 1,531 Answers
There may be a bad thermal fuse that is attached the cabinet of the burner area.check those and this may solve your problem as well as checking the ignitor
Posted on Sep 27, 2009
5 Suggested Answers
richroth
  • 9472 Answers
SOURCE: I have a Frigidaire Gallery
Here is a video that will walk you thru the diagnostic process for your dryer.
Posted on Jan 03, 2011
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
  • 2122 Answers
SOURCE: Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: my frigidaire gallery model fsg748gfs
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Were is the thermal fuse located on the frigidaire fde336res1
It is located on the rear bulkhead upper right hand corner. Ti access it you pop the top with a putty knife and remove the front panel. Get the drum out. I recently worked on one and did a video:
http://www.youtube.com/watch?v=wkog1i53T_k&list=UUKBjalPycKRmo4Mz9vRsydg&index=10&feature=plcp
http://appliancejunk.blogspot.com/2011/08/frigidaire-gallery-dryer-revamped.html
The smaller disk is the fuse. If blown the dryer will not run
Jul 07, 2012 | Frigidaire Dryers
Frigidaire gallery series , stop every 10 min. flashing ap , no heat .
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire gallery heats up but after a few minuts stops
heatman101
Aug 22, 2010 | Frigidaire FSG748GF Dryer
My frigidaire gallery model fsg748gfs gas dryer starts to heat up but stops after a few minutes?
heatman101
Aug 22, 2010 | Frigidaire FGQ332ES Gas Dryer
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire gallery model # GLG0642AS4 won't
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
heatman101
Apr 15, 2010 | Frigidaire FGQ332ES Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryers Logo
906 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
