My external hard drive no longer works, it appears to start but 30 sec later stops, it isnt recognised by windows. Any ideas?
  • MiAGon
    MiAGon May 11, 2010
    Is the drive making any unusual noises? Something new you have not heard before? Try re-seating the cables and reconnect.
  • 696 Answers
Lots of ideas, first things first, try it on a different computer. Sometimes software glitches get in the way, if it works on the other computer, we'll know it's the computer at fault, if it doesn't we know it's the drive. Second, if it also fails on the other computer you should swap the drive into a new external enclosure. If you're not sure/confident how to do this, take it to your local PC shop and have them do it for you, have the drive tested in the new enclosure. If it works in the new enclosure, buy the enclosure, problem solved, if it doesn't, let me know.
If the above suggestions fail, then the actual drive inside the enclosure is damaged. If this is the case you will need to enlist the help of a pro to retrieve any data on the drive. If you need a pro, let me know you location(Country, State and City) and I will give you some recommendations for your area. Once you pick a facility I will refer you into the choosen facility.
Hope this helps FixYa,
Chris
Posted on Sep 27, 2009
My verbatim external hard drive has stopped working. I plugged it in to a computer at work which cam up with "power surge" the light no longer comes on and it is not being recognised in my system device...
Disassemble the external drive and install the hard drive in a pc or place in a generic external drive you can purchase without a drive inside, then you can get access to those files again. The External drive interface has failed not the drive itself.
Oct 06, 2013 | Verbatim SmartDisk Firelite Portable USB...
No longer able to access my external hard drice
From your description it sounds like your drive has developed a case of bad sectors. It's a common problem.
I would suggest http://www.r-studio.com/ if you want to try recovering the data yourself.
Or have the guys at http://FreeDataRecovery.us take a look at it for you. They operate remotely over the Internet and work off of donations.
Feb 15, 2012 | Gateway Computers & Internet
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
I have a Western Digital external hard drive (MyPassport Elite) and it has stopped recognising it. I recently got a new laptop with Windows 7 after my last one with vista broke. It worked fine for the...
Make sure you're using the cable supplied. I have a Passport Drive that came with a 6" cable which I found to be too short. When I used a longer cable (and of an unknown quality) I started having intermittent read / write faults. I had the drive replaced by the store the next day. I started having the exact same issue with the new drive as well. I was told by the store manager when I tried to return the second drive that I should use the supplied cable, and when I did - it worked flawlessly.
Make sure your power supply (if yours included one) is connected too. Hopefully, the will solve your problem - good luck!
Nov 08, 2010 | Western Digital Computers & Internet
Problems access my My Book External Hard Drive
have you checked you usb connection? try unplugging it then plugging it back in see if computer recognises it then if not chances are your drive has failed
Jul 15, 2010 | Western Digital My Book Premium ES...
No longer recognised by laptop
that is a common noise when your HD just failed it can be internal or external drive most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck (beeping noise) or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | LaCie (300770) 250 GB Hard Drive
Astone 1 TB ex hardrive no longer recognised by computer
You need the device drivers for Win-7 for that hard drive to work. You can try to locate one on their website, but I couldn't find any....
http://www.astone.com.au/index.php?downloads=yes
Jan 07, 2010 | Computers & Internet
I need to run an HDD2159 external of its computer.
You cannot just connect the hard drive using a SATA to USB cable and connect it to the computer and expect to download data from this hard drive.
You need to connect the hard drive to an USB hard drive adapter which is then connected to a computer's USB port?
Leave the hard drive set as the master drive.
Oct 02, 2009 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
External hard disk and pcmcia cardbus
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Aug 04, 2008 | Computers & Internet
Seagate external hard drive - would not open
TRY THAT EXTERNAL DRIVE IN OTHER PC AND CHECK IF IT IS RECOGNISED THERE, BECAUSE IF IT IS NOT RECOGNISED THERE ALSO THEN LIKELY YOUR CASING IDE CONNECTOR *** CONVERTER HOUSING HAS PACKED UP.
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
