Question about Nintendo DS Lite Console
When i turn on my ds lite my top screen is solid
When i turn oon my ds lite my top screen is solid white. usually i wiggle the top screen a bit and it works but not anymore. Any suggestions?
    Scholar:
  • 50 Answers
Yes, this is a fairly easy problem to fix.
There are a few things that could have happened, the most likely thatone of you cable clips is loose, and when you open it fully, it pullsit out just enough so that the connection is lost.
Your going toneed to open your DS, (the forms at www.powergamingparts.com are thebest forms to find these instructions) then just disable your clip, andreinsert it, and then close the clip, and put you DS back together.Just ask if you need any additional help.
Posted on Sep 27, 2009
My DS screens don't work right
Hi, if you have 2ds's have you tried the other board, sound like the ribbon cables are definitely not pushed in all the way, wiggle in until the little lugs at the sides touch the white clip, could have faulty clips on the board and you definitely don't want to be changing them.
Enjoy
Jul 21, 2012 | Nintendo DS Lite Console
My Nintendo ds lites screen is not working i dont know why? the coulour is white on the top screen and it has white lines all over it but the bottom screen is fine. Please i need help may you please give...
Hello.
There is a problem with the connection of your top screen. Try bending it A BIT backward or forward until you get a display. BUT that is just a "temporary solution". You will eventually need to bring it to a service center and if it is badly damaged, they will replace the top screen.
Please rate my answer.
Aug 13, 2011 | Nintendo DS Lite Console
My DS Lite's top screen is blank white. Help.
a white screen can be due to two reasons 1. the screen is ruined which will cost you mush and 2. the display IC might have ruined which will not cost you mush .
Jul 07, 2010 | Nintendo DS Lite
My ds lite won't turn on both fuses are good the top screen was broke so I tried another screen I had that dident work. So I put the old one back on and now the ds wont turn on .The green lite flashes then...
It's all to do with the top screen... What happens is that when you turn the DS lite on it performs a quick check on the screens to make sure they are connected properly, if one or both are not connected properly then the unit will shut down.
The flashing of the screen shows you that that particular screen is fine whereas the one that does nothing is not connected properly, either through a loose connection or faulty screen/ ribbon.
Your best bet is to buy a new top screen (I usually get mine from ebay for around £10-£12) and fit it. That should sort out your issue.
Any further problems or questions feel free to message me via my profile page.
Regards,
SOD69
Feb 22, 2010 | Nintendo DS Lite Console
My nintendo ds lite won't turn on
This is usually the top screen at fault as the ribbon cable gets damaged when opening/closing especially if it gets sticky, from sticky fingers. Sometimes it's the bottom screen and sometimes it's a corroded motherboard(this needs my expert attention!). But 9/10 it's the topscreen.
Aug 04, 2009 | Nintendo DS Lite Console
Nintendo ds lite top screen has lines
sounds like possibly the ribbon, should get it checked incase it dies for good.
Apr 06, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
NDS Lite will not turn on
I hear about the ribbon cable not being inserted wel.
Lots of people had it put in place, looking ok but no action from the ds. I suggest to reinsert the ribon cables, i heard its quite tricky with the ds...
Apr 10, 2008 | Nintendo DS Lite Console
DS Lite touch screen
try to recalibrate the touch screen.
turn on your DS
go to the SYSTEM OPTIONS
last available box, recalibrate.
i may be wrong, but try that anyways.
Oct 21, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
153 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
