Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
When i on the camera it comes black black screen appears other things are in good conditipon
We have a Canon Powershot G12 camera. When taking a picture a red flashing camera appears at the lower left side of screen, the picture comes out white. What do we need to do?
That is the camera shake icon. When you press the shutter button halfway in low light conditions where camera shake is likely, a flashing (g0035839.gif) will appear. You need to change your settings to compensate, usually setting the camera on P or Auto will usually get you an acceptable image. Check the user manual or download it from the Canon website.
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwNDE5MTAx&cmp=ABR&lang=EN
Oct 09, 2014 | Canon Powershot G12 10mp 5x Digital Camera...
I was taking a pictures and all of a sudden the screen went black and now all the pictures i take come out black
The mirror inside your camera lenses appear damaged or displaced which is responsible for properly reflecting light (otherwise comes out black or too exposed). Send it back for repair.
Jun 29, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Sony DSC W40 , screen appearing black
ther should be a small button below the menu botton try pressing this a few times this a energy saving device .hope this helps.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
Sony dsc p51 cyber-shot. screen does not come on for pics. or video
I had the same problem with a P51 camera I bought from ebay. After searching on the internet for possible solutions. I found that this particular model had a problem with a sensor. Some guys recommended to hit the down corner (where the len is located) in your palm. I did it, and amazedly it worked, however, I need to do the same thing every-time the black screen appears. This is a Sony defect, the should replace the sensor. I have heard this solution does not work for everybody. Good luck!
Jul 06, 2008 | Sony Cyber-Shot DSC-P51 Digital Camera
Blank screen
Usually it's an lcd burn out where the screen needs replacement. Check the display button if it's just blank then press it to see if it comes on. As far as your friends white screen it not feasible to repair. A good thing to get on any digital equipment is an extended warranty. It does save you in the end when something goes wrong. The limited manufacture warranties are a joke. You should never rely on them.
May 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Black screen
Hey evafrech,
If when you turn the camera on the lcd screen is black could be do to an incompatible image has been selected as your start up image in camera settings. If this is the case you need to change your start up image. As far as your images coming out black make sure you are in shooting mode and not playback, and make sure the flash is working and that you are not too far from your subject. If none of this works I would have it looked at by an authorized service technician. Most retailers have a return/exchange period, and as long as you are still within that period you could just exchange it for a new one.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 23, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Black screen
Piece of junk that took great pictures for 1 year and now shows a black screen. Do not buy any Canon products. We also have one of these pieces of junk at work, now displays a E 18 code. Appears Canon wants to make mucho dollars by producing ****.
Apr 13, 2008 | Canon PowerShot S2 IS Digital Camera
Coolpix L4
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 21, 2007 | Nikon COOLPIX L4 Digital Camera
Black LCD Screen
Faulty main or secondary board. Could also be faulty light sensor or iris. Not a user fixable problem unless you can get another f601 with a broken lens etc with good boards (to replace boards). Or a dead camera with good lens assembly (contains iris).
Very fiddly if you have the parts!!!!!!
Best advise is to sell it as faulty on ebay.
Aug 31, 2006 | Fuji FinePix F601 Zoom Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
