Question about Panasonic VDR-D210 DVD Camcorder
Can't upload video from Panasonic VDR D210 to computer
I have finalized the DVD-RW and want to play it on my computer, but nothing happens, and I have no idea how I can get the footage off of there and edit in windows movie maker or any other thing. I can't even PLAY the movie, let alone edit. How are OTHER people using this camera?
My Panasonic Camcorder D210 broke and can't finalize my discs. What do I do?
Posted on Nov 27, 2010
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
I accidently formated my panasonic VDR-D210 DVD using the DVD recorder menu. Can I unformat the DVD and recover my video?
When you reformat again using the proper disk, you should be ok with formatting. Whether or not you can recover the video is yet to be seen. Regards, Joe
Dec 07, 2009 | Panasonic VDR-M95 DVD Camcorder
INCOMPATIBLE DISC
Good news.. you should be able to put the disc back in to the device that you recorded in on... and go to the menu to do the finalize... in fact, you may be able to add more to you disc prior to the finalize process if you want...
once it's finalized you should be able to view on other equipment... your files should all be there as well.
Let me know how you do!
May 26, 2009 | Panasonic VDR-D300 DVD Camcorder
How do I "finalize" the DVD video so it can be copied and played
Finally...was able to get to a copy of the owner's manual. I knew it would be a simple solution, just needed to get to the instructions.
Thanks!
Dec 14, 2008 | Panasonic PV-GS500 Camcorder
VDR-D210
the disc is most probally badly manufactured this is why it could not finalize. the only thing you can do now is playback the disc in the camera and plug the AV out into a stand alone dvd recorder and dump it to disc or hdd.
Jun 08, 2008 | Panasonic VDR-D200 DVD Camcorder
I want to finalize a dvd-rw to write to a dvd disk for viewing?
to finalize you must plug in your AC power supply. then finalize your dvd.
May 03, 2008 | Panasonic VDR-D150EF-S DVD Camcorder
Changing the mode to use USB on panasonic VDR-D100 DVD camcorder...
Try using only DVD-RW disc (not DVD ROM/-R/+RW) and format as "Video" mode. When you are done shooting finalize the disc. Then iMovie or your movie maker should recognize the video.
May 05, 2017 | Panasonic VDR-D100 DVD Camcorder
Inconsistently not transferring entire video
I use a 2.8gb Panasonic DVD ram disk on the XL quality setting. I do not finalize it when it is full. I place it in my computer drive, and use the Panasonic software that came with the camera to download it. It is stored as lossless mpeg2 in an untitled file in my Vista PC computer. From there I pick it up with either Windows movie maker or Pinnacle studio 11. I never lose a frame. I hope this helps you. I nearly lost my mind learning how to get the best quality out of this camera! It is very good for a consumer grade camera and the low price. The user manual could be written better.
Walt Barrett
wbarrett1@aol.com
Sep 04, 2007 | Panasonic VDR-D310 DVD Camcorder
How do I get videos from camera onto PC? panasonic VDR-M30PP
Sorry for asking, but have you installed the drivers that came with the camera onto your pc, because some of the software has this built in to enable you do as you wish with the recordings. Also PS2 consoles dont play all types of DVD especially DVD-RW, but normally DVD do have to be finalised before they are playable. If all else fails just uninstall the drivers that you got with camera and re-install before connecting your camera back up, if they were installed initially. Normally it's wise to install all the software bundle that comes with it, then later remove what you don't need and don't have more than one editing programme installed as they can conflict stopping your downloads. Hope this helps.
Oct 13, 2006 | Panasonic NV-GS50 Mini DV Digital...
Panasonic VDR-D210 DVD Camcorder Logo
416 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
