Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
While operating machine, brush does not rotate. Button is pushed in, all hair cleaned off brush. Is there a reset button? Where is it located?
Likely the wires are broken under the left hand cover not a difficult fix. Unplug the machine and remove the 4 torx screws and an access panel at the side of the ball. replace wires with new or re-connect with a splice. ensure wires are long enough to allow movement and you don't trap the wires when you replace the covers. about a 20 min job with the right tools
Posted on Oct 04, 2009
Dyson ball upright: Brush cuts on and off when you move handle down, or up just slightly. It'll be working fine, lower the handle down one inch, and it will quit rotating. WHY???
Posted on Dec 24, 2009
Brush bar doesn't rotate dc24
Hi there, it's Jack at Dyson.
DC24's brush bar is engineered to shut off for protection if something jams it. Once you've checked the cleaner head for any obstructions, and removed any threads or hair from around the brush bar, you should be able to reset your machine as shown in our video guide:
It may help to use something like the eraser-end of a pencil to press the red reset button - you should feel a click as it engages.
Please note, the brush bar will never rotate when your machine is standing upright. Make sure you recline your DC24 into the normal vacuuming position before testing it.
I'm confident this will resolve the issue, but if you would like some further advice from our experts, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Dc25 animal brush is not spinning,belt is ok,and thers no strainge noises or smells from it.
Hi Kevin,
Thank you for your inquiry. I am sorry to hear about this issue with your DC25 brush bar. Assuming you have already tried cleaning the brush of any obstructions, following the instructions below may resolve the issue:
1) Plug your machine into the power outlet
2) Locate the grey brush bar button next to your power button
3) With the machine turned off, press and hold the brush button down for 10 seconds
4) Release the grey brush button, step on the foot pedal to recline the machine
5) Press the power button to power on the machine
6) Check to see if the brush rotates
If you have any additional questions or require further assistance, please contact our US Dyson Helpline toll-free at 1-(866) 693-9766 or our UK support colleagues at 0800 298 0298. Thank you very much for your time.
Oct 06, 2013 | Dyson DC25 Vacuum
The brush will not turn
Hi Richard,
DC24's brush bar is engineered to shut itself off to prevent damage if something jams it. Once you've checked the checked the cleaner head for obstructions and removed any threads or hair from around the brush bar, you can reset the machine as shown in the video attached.
Tip: It can help to use something like the eraser-end of a pencil to push the reset button. When pushed correctly you should feel a click.
Please note: The brush bar will never rotate when DC24 is standing upright, so make sure you recline the machine into the normal vacuuming position before testing it.
I'm confident this will resolve the issue, but if you would like any further advice from our experts you can reach us directly by calling the Dyson customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Sep 21, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
No reset button for brushes
To locate the reset button on your DC24, please check the left-hand side of the cleaner head when the machine is facing you. It's set within a red recess - the video below may help.
If you're sure there is no reset button on the cleaner head, you may have a different Dyson upright. Please visit www.dyson.com and click 'Support' to identify your machine from the list. Our online Support guides should then be useful in resolving your issue.
Alternatively, we'll be happy to confirm which machine you own, and run you through the correct reset process, if you give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call.
Best wishes,
Jack
http://www.dyson.com
Mar 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
Reset blet button will not stay down. what does
Your rest should only be required once if the head stops. If it continues to shut off , you likely have hair or thread wound around the brush in the bearings or a motor which needs to be cleaned and lubricated.Try rolling the brush by hand if it is tight it needs service.
Most of these heads have a headlite housing which pops off to reveal two hidden screws. remove those and look for others near the neck of the head Once removed the housing lid comes off to allow access to the brush. remove the brush but be careful not to lose any spacer washers on the ends, Clean out any hair and thread and invert the belt to inspect if it has teeth , look for cracks or missing teeth. rotate the motor drive with your fingers. it should spin freely . If it is tight or grinds or scratchs you need to have it serviced or replaced. If the shaft feels tight 1 DROP of sewing machine oil or WD 40 on each end of the shaft will help, but clean out any dust first. the reassemble in reverse order.
Sep 16, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
DC07 bottom brush does not rotate.
I can not pinpoint what exactly solved the issue. I opened the bottom conver, cleaned any presence of hair, cleaned all hoses (yes hose was completely clogged), made sure that the brush bar was engaged by switching the selector back and forth few times from Carpet to Bare floor. (On bare floor setting, brush bar won't rotate).
Now I am happy that the vacuum is completely cleaned and back in operation!
Nov 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
504 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
