Question about Drills
Adj.clutch I am having trouble with the adj. clutch not working properly,when i change speeds from 1 to 25 or to drill the speed does not change.I am able to remove the chuck and the gears,but cannot see the problem.
  • acdc347 Sep 26, 2009
    Sorry for using the wrong terms,when i adjust the torque settings nothing changes,the torque is stuck
    Sorry for using the wrong term,when i adjust the torque settings from 1 to 25 nothing changes
  • 142 Answers
Those numbers have nothing to do with speed.
They are torque setting for the drill, so you don't overdrive the screw in....the smaller the number, the less torque.
Plz don't take you drill apart
Posted on Sep 26, 2009
How do cars with clutches work?
Clutches are useful in devices that have two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft drives another device. In a drill, for instance, one shaft is driven by a motor and the other drives a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds.Clutches are useful in devices that have two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft drives another device. In a drill, for instance, one shaft is driven by a motor and the other drives a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds.
-------------greebid.com
Nov 07, 2013 | Cars & Trucks
Drilling wood on a craftsman 10" drill press
There are several possibilities. I am assuming that by "hang up" you mean that the motor still runs, but the arbor, chuck, and bit all stall. I also assume that you are running the bit up and down to clear out the wood shavings from the bit out of the hole, you are using the correct amount of downward force, and that the bit is sharp. I would first check to see that there is proper tension on the drive belt. You can add a belt spray designed to increase friction for better running. I would also gear down the drill press even more to increase torque (I know you say you are running at the correct speed, but try a reduced speed). Another method is to use an auger bit or a forstner bit without pilot holes. If you are using a spade bit, you might try no pilot hole, and drill at a faster speed. I have a junk 10" drill press and have no trouble drilling 1" holes in oak.
Sep 14, 2017 | Craftsman Drills
I have a 18 volt cordless drill and am having trouble drilling screws into pressure treated 2 X 4's. What are the proper adjustment settings for denser (and lighter weight)...
Tighten clutch all the way. If you are using pressure treated that is dry, pre drill the holes. Use full speed/Hi speed. Be aware if you live in the USA, the "new pressure treated" wood requires special screws. The "old" screws will be eaten by the chemicals in the "new" wood.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Ryobi Garden
First I replaced the pipes on my 06 650 yamaha v star custom with V&H cruzers. I then re-jetted the carbs. Now I can't get a low idle. I checked and adjusted the float level. replaced the pilot jet (#...
FIRST, YOU DIDN'T NEED TO REJET THE CARBS. I WOULD PUT THE STOCK JETS BACK IN IT WILL RUN JUST FINE. YOU NEED TO HAVE IT RUN ON AN EGA MACHINE TO TUNE IT PROPERLY.
Nov 09, 2010 | 2006 Yamaha V Star Custom
I have a 2001 ducati 748 when i put the bike in any gear the bike just moves slow but the engine revs if i rev slow the bike will pick up speed
Time for some new plates in there. I have an 02 s4, and my clutch did the same thing. had to get a clutch pack and put it in, fairly easy job. you have to get the old one out and measure the plates to see if they are worn etc, new seals, bearings, plates, springs. I would check the adj on my clutch lever first to make sure it is right. Also, when mine first started slipping, it was real hot out. It cooled down that day and worked fine, but I had trouble from then on, slipping. Had changed the oil and everything to try and fix it. Hope this helps.
Aug 28, 2010 | 2001 Ducati 748 R
My dewalt drill won't drive
is your battery is fully charge or maybe your clutch setting are too low. set it drill mode if it is not working you need to replaced
trans/clutch assy
May 28, 2008 | Dewalt 18 Volt Compact Drill Kit
18 volt xrp hammer drill driver
run the drill slow while changing the speed of the drill
Mar 22, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
110 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
