Question about Canon PowerShot A410 Digital Camera
Overexposed outdoor shots.
I used my a410 canon for about 3 years ago. It has a good shot since i first used it and i can capture clear and fantastic outdoor and indoor shots. Now my outdoor shots turnes into white as in no detail at all but white. and the thing that bothers me more is there is so many horizontal lines in my digicam that blocks the quality of the picture itself once the picture is taken. (some pictures only)
zohail
  • 1223 Answers
SOURCE: Bright images outdoors, sometimes with horizontal lines
CCD Failure !!
u are lucky get it repaired free of charge postage paid just call Canon in ur area and they will do it see link below and Pls rate me FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Posted on Apr 24, 2009
t00nz
  • 4738 Answers
SOURCE: I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Posted on Jul 05, 2009
SOURCE: my camera displays a "white screen" when i take photos "outdoors" or during daytime outside
repair CCD image sensor failure Cannon Powershot A410
Posted on Jul 26, 2009
Rammsteins
  • 300 Answers
SOURCE: Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Posted on Jul 29, 2009
  • 67 Answers
SOURCE: My canon a470 produces a blury image after taking the shot.
hi,
you must have a lance problem,so please contact any authorised person for repairs , its may be a lance flap is cracked,
Posted on Aug 31, 2009
My canon S2IS takes great shots indoors but in natural light, as outdoors, the pics all look white - overexposed
You need to add a Neutral Density Filter appropriate to your camera. This will remove the excess glare and reflection from your shots. See a good camera shop of look at an accessories list for your camera to select the proper one that matches the screw threads of your camera.
Mar 12, 2015 | Canon Cameras
I bought my camera 4 years ago but till now still i cannot get a picture of me in my canon power shot A410, the problem is i dont know the steps in setting timer to get me a picture. can you please teach...
Press the FUNC/SET button. Use the cursor keys to select Drive Mode. Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
Full details are in the "Using the Self-Timer" section of the advanced guide. (page 35 in my copy). If you need any of the manuals, you can download them from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a410#BrochuresAndManuals
Aug 02, 2011 | Canon PowerShot A410 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
I can't figure out how to set the 10 second timer for my Canon A410..HELP!!!!
With the camera in the shooting mode:
1. Press the Func/Set button
2. Use the up or down arrows to select the Drive mode (normally a single square)
3. Use the left or right arrows to select the clock/10 icon (10 sec delay)
4. Press the Func/Set button again
To cancel, follow the same instructions but select the single shot mode (single square) at step 3
Aug 28, 2009 | Canon PowerShot A410 Digital Camera
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
My camera displays a "white screen" when i take photos "outdoors" or during daytime outside
Are you sure that you are in full "auto" mode when you are taking your pictures? Make sure that the mode selector is set to the first red camera (without the M) right next to the little blue arrow.
If you already are in full auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Your camera is not capable of taking 15 second exposures. Instead try putting it in manual mode, turn off the flash, take it in a darkened room, take the picture, and open the battery door while the red and yellow lights are blinking. Give it several tries, but note that the chances may be very slim for success as the shutter symptoms suggest that it is stuck open.
Jun 02, 2009 | Canon PowerShot A410 Digital Camera
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
A410 (PC1156)user manual needed
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=11930 Good Luck!
Aug 11, 2007 | Canon PowerShot A410 Digital Camera
Continuous video capture
Hi, The A410 can only record a maximum of 3 minutes. That sucks becasue it doesn't matter what resolution you use, it will max out at 3 minutes. NewMediaMan
Apr 24, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot A410 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
