Question about Garden
Digger ec15bxtv;looses engine revs when working
digger ec15bxtv; looses engine revs when working hard.
engine stools at low revs.worse when hot
  • 235 Answers
Dirty fuel filters or fuel is starved somewhere.
Posted on Dec 31, 2009
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
Audi 2.5tdi white smoke on exhaust low revs
Hi
White smoke is usually a good sign of un-burnt diesel so reading your post and all the things you have already changed ie the glow plugs I would have the injectors tested to make sure they are atomising properly as it sounds to me like when your car isn't under load ie at low revs you have a cylinder that isn't firing correctly
Hope this helps Nick
Aug 27, 2017 | Cars & Trucks
My Kohler Cimarron has a blockage. I have used a plunger and tried dish soap and hot water. also poured 4 buckets of water. Not blocked by a foreign object. plz help JMP
Probably something stuck in the Trap of the stool unless your main line is stopped up. If you cannot plunge it, you may have to take the stool loose from the floor, unhook the water line, and turn it upside down out in your yard. You will be able to view right up into the trap of the stool . Otherwise, you can go buy a small stool snake and try to root it out on your own. Good luck, this is no fun.
Apr 21, 2011 | Kohler K-11465-0 White Cimarron Comfort...
Transmission issues revving up and not going in gear smoothly
I sounds like you may be low on transmission fluid. Its hard to say with the limited information yuo have given. If you put it into drive and the vehicle sits there and you give it gas and the engine revs up and then slowly starts moving, it is a transmission problem. If it is low you may have already done irreversible damage. The problem will get worse very quickly. Check your trans fluid immediately.
Sep 16, 2010 | 2004 GMC Sierra
Honda accord aerodeck 1996,looses power going up hills,over revs sometimes but does not accelerate,smells of hot eletrics when has over revved and leaks orangey brown liquid from somewhere under engine
If its an automatic transmission I think its your torque converter. The fluid your seeing is transmission fluid. If I'm right it will get worse quickly without repair.a0174f0.png
Dec 18, 2009 | 1996 Honda Accord
I have an old Ford 550 digger clutch failure
if its a hydraulic clutch & conneted to the same system & its low on fluid then that will be your problem
just top it up & try it you may have to bleed out the system of air if it doesnt work!
Jul 19, 2009 | San d Digger
Engine knocking
Good news is - I don't think you need a new engine.
As there are many moving parts that could create a knocking sound, it usually needs careful inspection to identify where it is from.
I will give a list of some of the causes and remedies. Yours will probably be one of them, but unless I was there - it could be any.
Loose exhaust component (causes rattles and thumps) - replace parts or joints.
Loose Engine mounts - Engine will move about a lot more than normal - Replacement of mounts.
Fraying Belts - causes continual ticking or slapping - Replace belts and check tension.
Timing is off - bad running, lack of power, pre ignition or knocking at low revs. Check timing belt - Replace, Tune engine.
Cracked valve - slight misfire worse at low revs - Replacement valves.
Clutch Problems - Broken spring or loose bolt - Check clutch plate - replace clutch plates.
Older engines - often accompanying smoke -
Broken Piston ring - continual ticking or occasional misfire - Replace Piston rings
Worn Piston bearings - Piston Slap - Replacement of all piston bearings.
Transmission Problems (only heard when in gear or with clutch out) - Broken gear teeth or worn bearings - Replacement of Transmission or rebuild.
Some of these remedies require engine removal and strip down, others are a simpler fix.
Dec 26, 2008 | 1990 Cadillac Fleetwood
1998 Holden Rodeo TR series 5-speed manual 2WD
run the fault codes
look for ambient temp sensor or baro sensor problems
Jun 30, 2017 | 1992 Isuzu Rodeo
Digger how to
Hammer rebar into the ground to create pathways for water. Grab a hose and soak the ground to soften it before using the post hole digger. Wait until the water has had a chance to soak in. Raise the post hole digger and drop it, jaws open, into the ground. The jaws will cut into the ground and soften it even more for removal. Continue to use the weight of the post hole digger for the hard work, circling around the edge of the hole. Drop the digger down with force once you've loosened up a circle of soil. Open the handles to grab a bite of earth in the jaws and lift it out. Continue with Steps until you've removed all the loose soil, making a hole 1 foot in diameter.
Aug 27, 2008 | Woodland International Chipper Knife for...
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
