Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
I have a Toshiba cx35e70
By clete47 on Sep 26, 2009
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked fine. The problem would return after the set was turned off again for an undetermined amount of time. A tap on the tuner again was the fix until the power was turned off. Pulled out the mainboard and re-soldered tuner pins and checked for broken traces. After that all worked fine for awhile. Now, the set has a live screen with a quick flashing picture with no sound. The tap on the tuner, or anything else, is no longer the cure. Picture and sound works perfect with VCR playback but the same when using the VCR for the tuner.
Solution #1
posted on Sep 27, 2009
Not Rated)
palaboy
Rank: Wiz  Televisions & Videos  Expert
Rating: 83%, 1239 votes
hi,
A) basing of what you have mentioned:,
" Pulled out the mainboard and re-soldered tuner pins and
flashing picture with no sound. " ,
you need to use magnifying glass to look for your
accidental shorted paths. which may have been
caused by resoldering the board.
B) now you have another trouble , flashing picture,
C) the trouble you are having may be caused by the tuner.
D) for tuner:
1) you may need to disable the tuner pin voltage supply
2) once it is disabled turn again if problem still persist
3) if, it is, means the trouble is not on your tuner.
E) assuming that tuner is still disabled ( no supply), you
will now go tracing back to the horizontal deflection
circuits.
F) under horiz def there are horiz out, flyback transformer
horiz drive transistor and transformer. these main components
are the most essential part of the TV.
without them your TV wont work.
G) the reason why the sound and picture cuts-off due to
the failure of the horiz oscillator.
H) there is also a possibility of intermittent supply on
I) also a possibility that the horiz osc is being blocked.
J) check also the power supply circuits monitor the
supply to the horiz def circuits, might also be
intermittently failing.
k) these might seems odd but include the vertical circuits
include the output capacitor with vert IC.
All of these are just possibilities,to be precised you need
a service manual just to point to you where the trouble
might be.
have someone to helped you trace circuits, it can be done with
a help.
osc = oscillator
horiz = horizontal
vert = vertical
hope i have helped you, thanks for using Fixya!
Was this helpful?
Yes
No
Solution #2
Not Rated)
johnnydiode
Rank: Guru  Televisions & Videos  Expert
Rating: 92%, 238 votes
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
I have an RCA 52" screen TV and I was watching tv and all of a sudden the picture went blank... (More)
Answer
the screen does not include the left side or right side text on news and sports broadcasts.
Answer
My RCA television will not turn on. Power button flashes red for several seconds and then stops... (More)
Answer
I have a lcd tv, model# lc195slx, I cant seem to connect it to my pc. When I do it says "format... (More)
Answer
my child pressed a button on the Dish remote, now the word mono is stuck on the screen and the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
