Question about Motorola Mobility HS850 Consumer Headset
The microphone is not working on my HS850. Noone can hear me.
  • jodyny Sep 26, 2009
    We'll have to see about finding a screwdriver small enough to get at that screw! That sure is tiny.
    It may work, but we don't have a small enough screwdriver to take this headset apart. We'll work on it though.
  • 169 Answers
Hello! I had this exact same headset before I got my current Jawbone - and I had the same problem after about 8 months of pretty heavy usage. I did some searching and found a fix that worked, but it involves taking the unit apart, but is otherwise quite simple (and worth it, IMO) :)
Start by removing the plastic cover that surrounds the main button on the front. This can be done by firmly holding the headset and gently prying up on the lanyard loop (as indicated by the arrow) - this plastic cover is simply held on with double sided adhesive. Once you have it removed, you will see a small Torx head screw (size is T5). Remove the screw and the headset can be pulled apart. NOTE: Do this over a table or tray so that if you do happen to drop the button, or the spring under it - you can find it again. :)
Now - my problem was the spring under the button - and I use the term spring very loosely here - it was actually just a piece of foil and tape - was sitting on the board, and not actually working to activate the button. If you simply reset that tape so it doesn't contact the board - it should work again. At least mine did.
I hope this helps and good luck! Thanks for using FixYa!
Posted on Sep 26, 2009
I bought a logitech desktop 600 and noone can hear
Try to go into your control panel, Audio, then select the microphone as input. Should work now, try into the sound recorder. start menu, all programs, accesoiries, entertainement, sound recorder. Have a nice day. Cren
Feb 25, 2010 | Logitech (980240-0403) Microphone
Microphone isn't working on my hs850
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.possible you are experiencing this . i did
Dec 06, 2008 | Motorola Mobility HS850 Consumer Headset
Microphone...
You need to clarify whether microphone or its connection bad or system causing the problem. I suggest you to try with external bluetooth or normal headset. If sound microphone works with headset you need to have microphone connection be fixed
Jun 19, 2008 | Nokia E90 Cell Phone (Unlocked) - Black
Ge headphone
Try another microphone or headset with a microphone that you know is working. If the replacement works, the new GE has a bad mike or connector. Return it for a replacement.
If they both don't work, you have a computer problem to resolve.
Hope this helps :)
Apr 01, 2008 | GE (JASHO98334) Headphones
Motorola HS850 Bluetooth
Whats most likely wrong with your HS850 is the connect button on the front of the headset (the larger oval chrome one with an inlay of a traditional phone handset on it)is stuck down. To repair this you will hold the hand set and pull up on lanyard attach point firmly. (This facia is held on by double sided tape). After pulling the facia you need to purchase or borrow a T-6 Torx bit to remove the screw that holds the headset together. Once you get to the circuit board you will see what the button and spring assembly are (all is is a round piece of foil and the "spring" is a piece of tape using tension to pull the foil up!) Reset the piece of tape so it does not rest on the board and reassemble that headset. Enjoy your HS-850
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Microphone doesn't work
unit needs to be replaced with new one go to www.n1wireless.com to get replacement cheap
Apr 08, 2007 | Motorola Mobility HS850 Consumer Headset
Can't Talk
mic connection has a short go to www.n1 wireless.com for new headset cheap
Dec 31, 2006 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
