Question about Refrigerators
Fridge draining hole is not blocked but is filling with water daily
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Try pushing a stiff wire through the hose leading from the freezer compartment to the drain pan
Posted on Dec 18, 2007
I have an LG model LDS4821 dishwasher that quit washing clean. Top rack is the dirtiest. Water is hot and bottom drain is clean.
The most likely cause is a blocked or clogged wash arm. Many times when the wash stops the debris blocking the spray will back away. The holes in the arm are aimed to cause the arm to rotate. The clogged hole is usually an outer diameter hole which provides the force for the arm to rotate.
Some upper end washers have a blocked arm sense to alert when arm is blocked.
Careful not to deform the geometry of the hole when removing the debris. Tweezers work the best.
26281729-v4uvew3xjjdpgmn3ctj2lcyg-4-2.jpg Hope this helps?
Sep 13, 2016 | LG Dishwashers
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
How do i unblock the drain hole of my Miele kfn12823sd fridge freezer
Water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up like If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain lines. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 11, 2013 | Refrigerators
Ford fiesta door filling with water
The drain hole on the bottom of the door is probably blocked. Use a thin wire to clear the drain holes.
Jan 22, 2012 | Ford Fiesta Cars & Trucks
I have water coming in on driver side. It sometimes pours out the screw that holds sun visor and also were roof meets the side panel in front of door. I have a 2005 Mercury Montego. Where would water be...
Looks like your sunroof drainage hoses are blocked, due to dirt and dust.
On that sunroof corners have these drain holes, water passes thru those holes and a hose attach to it. It will lead the rain/water to the side and to the bottom of the window/windshield pillar.
Those drain holes are already blocked that's why its over filling that area with water.
Get a flexible bicycle cable and insert it to those holes and pour a little amount of water w/ laundry soap, until the water flows out.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | 2005 Mercury Montego
A stink bug climbed in the water chamber and we can't get it out. is there a solution?
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
Mar 07, 2011 | Rowenta Professional DX8800 Iron
I don't know the name of the part, but there is a daily leak coming from inside the refrigerator about the top shelf near the back. We placed a bowl there to collect the water
most likely the drain hole is clogged. So everytime the fridge goes on defrost, thetes no whete for the water to drains so it drains down into the refrigerated section. Remove back panel in freezer. Drain hole is located under the evaporator. therte should be a thin metal pan under evap and drain hole is in the middle of pan. Remove ice and clear drain hole. Pour hot water down it and listen to make sure its flowing into drain pan under rrefrigerator.
Mar 04, 2011 | Kenmore Refrigerators
A small amount of water is accumulating on the floor just below fridge on right side. It does dry up but returns daily.
That will be the condensation from the water vapour produced by food in the fridge. There is a drain hole at the bottom rear of the fridge.
Jan 13, 2011 | Microwave Ovens
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Refrigerators Logo
339 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
