Question about Miele S514 Solaris Bagged Canister Vacuum
How do i disassemble (i.e. which screws do i pull and which hidden tabs are there) the cord retractor/switch assembly? there is only one screw that appears to hold the piece but it does not come out, Thanks
There are 7 torx head screws to remove in the top plastic housing. 5 are in the perimeter and two are "hidden". One is under the power/cord winder panel which pops off in an upward diredtion. and one is under the cloth filter on top of the motor, inside the bag compartment. Take out those 7 and lift the plastic top panel off !
Posted on Jan 12, 2010
  • Rich Ferrier
    Rich Ferrier May 26, 2014
    thanks, found the one under the cloth filter. No way it not for you. :-)
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
Kenmore 116.26212602 cord won't retract completely
This is a common Kenmore problem. The cord may have kinked inside the cord reel, You can remove the top by taking the screws out some are hidden under the switch. If the cord gets too close to the edge of the reel it can bind. Do be careful as the spring in the cord reel can jump out and it hurts. I would take it to a dealer.
Jan 31, 2014 | Vacuums
Bosch bsg8pro1gb
Do you know how to get at the cable retractor assembly on a Bosch BSG8PRO1 vacuum cleaner. Mine has completely locked up. I can only locate 4 screws but they dont release the top and i dont want to force it.
Nov 23, 2013 | Vacuums
How to replace the power switch on a Kirby G4
This repair requires extensive disassembly. First remove the handle, bag assembly, and switch "scuff" plate. To remove the switch plate, remove the screw at the bottom, and the upper screw that secures the cord. Insert a screwdriver into the rectangular slot in the plastic and pop it off. The cord must also be removed. One screw holds the cord cover to the lower motor shell. Remove the screw and push with a flat screwdriver on the back of the cover to unlatch it. Next remove the upper motor shell ( 4 screws ). The next piece to come off is the switch button. Pry upward on it's attaching lugs to free it, pull it upward far enough to disconnect it from the switch rod. The power drive assembly is next to go. Three screws on the bottom of the motor unit hold it in. DO NOT remove the center screw beneath the shift lever. The drive pedal must be in DRIVE for removal. The transmission drops down to get it out ( you may have to wiggle and pull on it to free it). Next the headlight frame assembly must be removed. You will see 2 screws at the rear, and 2 long screws in front which also secure the fan housing. After removing the screws, the headlight frame can be removed. Be careful to note the proper location of all wires! The right carbon brush assembly must be removed to allow the switch to slide back for removal. It is held in place by 1 screw and a tab on it's holder. Two screws hold the switch itself in place. One is on a tab on top of the switch, and the other is on the right bottom of the lower motor shell. The lower screw also serves as a motor mount screw. The switch can now be removed by inserting a small screwdriver along it's front edge and prying it backwards. It is wise to clear dust and lint from the motor contacts prior to re-assembly. Be sure the terminals on the field coil have not gotten bent before putting the new switch in place. Snap the new switch in place and replace the screws. It is easiest to replace the wires in this order:
1- Holding the headlight assembly off to the right, install the lower headlight wire.
2- Next connect the wire from the left carbon brush to the upper switch terminal.
3- Connect the upper headlight wire.
4- Gently replace the right carbon brush assembly, secure it with it's screw ( do not overtighten ) , and connect it's wire to the lower switch terminal.
After the switch is in, install the headlight frame screws, transmission and belt, and switch button in reverse order. Be sure the shift arm on the left side of the drive unit engages the slot or pin on the handle pivot assembly. The cover and trim pieces can now be re-installed.
Feb 16, 2011 | Kirby G4 Bagged Upright Vacuum
How do you replace the top shell of the Rainbow D series? It doesn't look like the wires can be disconnected without cutting.
To replace the top cap of a D4 Rainbow vacuum:
Remove the separator.
Remove the 4 screws on the bottom.
Pull the bottom off around the foam tank gasket.
Remove the next 4 screws.
Carefully pull the wiring up through the middle section wire hole.
Remove the top cap 4 screws.
On the bottom of the switch there are 4 fingers, one on each corner.
Push the fingers towards the center of the switch and push the switch through the rectangular hole
Pull the wire through the middle section and the top cap to give you as much loose wire as possible.
On the long sides of the switch near the wires are 2 small round holes with small semicircular tabs pushed through the sides of the switch assembly. These tabs hold the wire assembly in the bottom of the switch. Very carefully push a jewelers screwdriver between the switch body and the wire assembly on each side simultaneously to release the tabs and pull the wire assembly from the switch body. BE VERY CAREFUL. Do not pull the wires hard. The wires are held in the wire assembly by small friction clips. They are not soldered or attached except by the friction clips. These friction clips fall out very easily. The twist in the wires alone will pull them out of the friction clips. So hold onto the wires in such a way that they cannot twist free. If you loose a wire or two, you will have to push them back in and reset the friction clips. This was a challenge of dexterity. During factory assembly, The wires were probably pushed one at a time into the bottom of the completed assembly. You could record the position of each wire and replace them as the factory did. This was the most difficult step as the switch came apart very quickly and without warning and the wires very nearly separated from the switch assembly.
Remove the old top cap from the wires and replace it with the new top cap. A 3rd hand may come in handy.
Push the wiring assembly back into the switch body the same way it came out.
Push the switch back into the top cap.
Reassemble the vacuum.
Jul 09, 2010 | Rainbow Technologies D4 Bagless Vacuum
Also have a Kenmore Model 116. Power retractor not holding cord
The cord winder on these is spring loaded and has cog which is meant to lock with every full rotation of the spool the cord winds onto. It is tricky to work on.
Try pulling a bit more slowly and see if the rewind will stop.
The back housing on top of the vac needs to be removed to access the rewind. The housing snaps into place at the back corners, generally must be carefully pried and popped off by someone familiar with the vac. Some models may also have 2 screws under the lid in the bag area.
Sep 10, 2009 | Kenmore Canister Vacuum Vacuum
How do you disassemble Rainbow D4c to replace power cord? Took four screws loose but unable to see how to get housing loose...
Gently pull on the rubber gasket that seals the water tank to the canister. Although there are more screws under there - they aren't necessary to remove only to replace your cord. It is the gasket that is holding the motor flange and the plastic housing together that hinders your progress. If you're gentle about pulling off the gasket and it's in good enough shape, you can usually put it back on with some rubber cement (the same thing it is originally attached with) when you're finished. If the gasket breaks, it would have to be replaced - but not a big deal - they aren't really very expensive.
May 09, 2009 | Rainbow 75th Anniversary Canister Vacuum
Bad on/off switch hoover U6476
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Disassembly of Miele red star?
First remove the lid by opening it and pulling straight up while using a screw driver to pry on the black hinges that go straight down into the unit. After that there are two silver screws on the black pedal assembly pull up and back to remove this assembly . Remove the HEPA filter. Remove the screws under the pedal assemble and pull straight up. What ever you do do not remove the cord winder assembly it wil spring and you will have to replace it. For any parts,filter or bags for this or any other unit visit www.stevessewandvac.com
Aug 12, 2008 | Miele Vacuums
Fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
Sep 28, 2007 | Vacuums
Miele S514 Solaris Bagged Canister Vacuum Logo
252 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
