Question about RCA TruFlat 27F520T 27" TV
I am getting a blue screen. It is hooked up to a satlite and is on the same channelas the satlite box. What am I doing wrong?
  • 647 Answers
If the TV is usually viewed on channel 3.
On the remote control (original RCA TV remote) manually enter the digits 0 and 3 -the tv should display 03 and work - if this dosn't work plug three wires from the back of the satellite box which say out to tv - video and audio left right. plug the othe end to video/audio input 1 on the TV (matching the colors then press the video (or source button ) on the remote. Be sure the satelite is on (green light is on)
Posted on Sep 27, 2009
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
Hook up extion speaker to my coby tv it hook up to satlie tv
find R-out, L-out & connect to home theater R-in, L-in.
May 31, 2012 | Audio Players & Recorders
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
How do I find the cable channel on my Poloroid 3211? All I get is a blue screen saying"NO SIGNAL"
It indicates a no signal issue--either not hooked, wrong input etc.
It could also mean the set needs a reset if it has it---Check with Polaroid concerning this.
What I would first do is see if the rear audio/video inputs work--hook a DVD etc to a rear input--go there to that input and see if working.
If rear inputs work and you use a cable box, go from the a/v inputs on box to a set on the TV----this will bypass the TV tuner and allow you to operate the set that way.
Mar 27, 2012 | Polaroid Televison & Video
A blue screen
This is an analog tv,buy a digital converter box to hook it up where,ur dvd player was hookup + buy a digital antena to get a good receptions.Follow the digital converter box instructions.U will hook it up correctly and have free DTV air brocasting signal.
Jun 23, 2010 | Toshiba 27A33 27" TV
My settop box has given me a blue screen and now i
A Blue Screen, means that there is NO signal be "Given" to the "Input" that the TV is currently using. Try another "Input" or check your antenna is OK, you are "ON" the right "Input" too.
Mar 02, 2010 | Televison & Video
Blue Overlay On Screen
The monitor has to be the problem if you hooked others up with success. Get the monitor replaced.
Dec 14, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Sound
Component jacks are for video only,,hook up some rca jacks with them in the audio red and white plugs. that should get ya there,, thanks
Oct 05, 2008 | Hitachi 53SWX01W 53" Rear Projection...
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
196 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
