Question about Cameras
How do i turn off the flash to a SL 30 - Cameras
Where is air pump fuse on 99 saturn sl 2
IGN 4
Green (30)
Feeds directly to A/C Relay, AIR PUMP Relay, WINDOW Relay. IGN 1 (10), TURN (10), B/U LP (10), EGR (10), EIS (10), PCM I (10), INJ (10), WIPER (25), AIR BAG (10), RADIO (10)
Located in the under hood fuse box .
located in the under hood
Jul 08, 2016 | 1999 Saturn SL
My 2002 Altima SL 2.5 drives and shifts fine for an hour or so. Then it won't shift from first gear.
In spite of what Firestone did it still sounds like you have a defective speed sensor. Other people have also had this problem and it was solved by replacing the speed sensor.
I hope it resolves your problem.
Sep 22, 2014 | 2002 Nissan Altima
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
COMMON SPA PANEL MESSAGES
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
What type of transmission fluid for a toyota rav4 1998
We have five recomendation for you. Out of this, SYNTEC oils are most recommended for your vehicles. CASTROL EDGE, SAE 5W-30 PI*, SL 5W-30 - an advanced proprietary formula that provides performance and protection in extreme conditions such as towing, hauling, high and low temperatures, rapid acceleration and stop and go traffic. CASTROL GTX HIGH MILEAGE, SAE 5W-30 PI*, SL 5W-30 - CASTROL GTX high mileage - helps extend the life of your engine. CASTROL GTX, SAE 5W-30 PI*, SL 5W-30 - `superior sludge protection. CASTROL GTX exceeds demanding U.S. high shear and stay-in-grade requirements for viscosity breakdown protection. CASTROL SYNTEC BLEND, SAE 5W-30 PI*, SL 5W-30 - CASTROL SYNTEC blend - CASTROL SYNTEC blend is specially engineered with proprietary CASTROL GTX technology and CASTROL SYNTEC molecular components to provide superior short?trip protection*. * 5W30 AND 10W30 ONLY CASTROL SYNTEC, SAE 5W-30 PI*, SL 5W-30 - IN extreme tests, CASTROL SYNTEC 5W-30 maintains maximum horsepower longer than the leading conventional oil.
Sep 19, 2010 | 1998 Toyota RAV4
What type of engine oil will need for my toyota
FULLY SENTETACHIC OIL ,VERY GOOD FOR ENGINE WITH ALOT OF MILES KMS UP
Jun 18, 2010 | 1998 Toyota RAV4
My sl 280 1997 wont start, it turns over ok,the two lights for the alarm in the rear view mirror are flashing red and green is there any way i can bypass the imoberlizer
Point remote at mirror
Press lock/unlock button twice
Within 30 seconds turn ignition to position 2
Should reset if you have no other problems with immobilizer
Jan 04, 2010 | Mercedes-Benz SL-Class Cars & Trucks
My engine coolant light flashes when i start my car then after like 30 seconds it goes off.why?
the coolant maybe getting low ,check the resivor and see how much is in it,only check it when the car is cold as you dont want to burn yourself
Oct 12, 2009 | 1998 Saturn SL
20002 Saturn SL, replaced steering column. How do I...
Try to start the leve key on for 10 min, turn off (wait 10 sec) then try to start again and leve on for 10 min again, turn off and try again wait 10 min, turn off for 30 sec and then start engine.
Jul 26, 2009 | 1999 Saturn SL
What is a tps sensor and what does it mean to be re-flashed.
TPS is Throttle Position Sensor and Its Purpose is to Tell ECM What You Are Demanding of the Gas Pedal , it Senses Where the Gas Pedal is --
Reflash= Relearn that is When A NEw Sensor or ECM Controlled Component is Installed and ECM Must Relearn the Electrical Values of Components. To Relearn you Must Do the Fallowing.
Turn Ignition Switch On and Leive it on for 10 minutes then turn it off for 30 Seconds then turn it back on for 10 mins Do this a total of 3 times totaling 30 minutes ALL Without Starting Engine Just Turning KEY to ON Position.
Feb 12, 2009 | 2000 Saturn SL
Cameras Logo
82 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
