Question about Audio Technica Audio-Technica AT4040 Professional Microphone
I have a low level hum in the MIC like a motorcyle in mt AT 4040
I have a low level hum in the MIC like a motorcyle idiling 100 ft away for my AT 4040
  • 5,603 Answers
Remember this is a condenser mic that REQUIRES phantom power. There are several failures regarding this phantom power delivery that COULD cause your problem.
A "LEAKY" mic cable that is not a fully balanced cable can cause the problem. Test with another cable to exhonorate your cable.
A failure of the input bypass caps in your amp/preamp can cause the input to become unbalanced and let in hum.
A phantom power that is improperly filtered can also cause this. Test using a different source of phantom power.
Remember that you can easily get feedback that may oscillate like hum if you have a monitor speaker anywhere in "earshot" of the mic. They are very sensitive and intended for studio use.
Posted on Oct 04, 2009
Ft-2800m hum on tx
bad mic cable, bad capacitor somewhere
Apr 16, 2014 | Yaesu FT-2800M VHF Transceiver
Bmw 335I Problems Humming in car. Goes away when
First thing I'd check is the power steering fluid level. If it's low, add until it's at the proper full level as indicated on the cap/dipstick for the pump's reservoir. A low level can cause a humming or slight grinding sound. If it's full, you could have a rack-and-pinion problem, a wheel bearing problem, or even a tire problem. Good luck.
Sep 30, 2013 | 2007 BMW 335i Coupe
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
My midland 1001z has power to it but all it does is give a humming sound!The mic. will key up and the tx light comes on but when I release the mic. the humming sound gets louder,is the unit screwed? thks...
If you are using a power supply. Get you a better power supply(full filtered) RADIO SHACK has many 12 volt 3 amp models. Run power wires away from radio about 10 feet away to eliminate hum. AM does hum when its near power lines, household appliances. Keep it away from TV's etc. Turn off TV then listen to it. Make sure you have good outdoor antenna like Antron A99 18ft. Fiberglass on Tv pole or Tower. If its inside car --its the engine. you need a Radio Shack Power filter. A coil of wire wrapped around a core and big capacitor on the (+) side shunted to ground by a 470uf Capacitor. Turn off engine then listen.
Apr 04, 2011 | Midland 1001Z 40-Channels Base CB Radio
When I record with the internal mic or the BA
I had that problem too. What you need to check is the input level on the right side. Turn the wheel all the way up to 100 and the internal mic should be fine.
Feb 07, 2010 | Boss Micro BR Digital Recorder
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
Audio technica at 4040 constant ground hum noise
you can test the cable from connection to connection for continuity from end to end. There should be no resistance( a complete short) If the cable is good, there is a bad or broken connection inside the mic. Good Luck
Jun 23, 2007 | Audio Technica Audio-Technica AT4040...
Open Questions:
Audio Technica Audio-Technica AT4040 Professional Microphone Logo
207 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
