Question about Epson Stylus C40UX InkJet Printer
How do you change the ink cartridge on a epson stylus c40ux
  • 624 Answers
SOURCE: how do i take out the ink cartridge
Hi Kalola, Here is the link to the document files for your printer, the one labeled *Product Information Guide* is the users manual: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14419&prodoid=4742578 Page 6 covers the removal and replacement of cartridges. Let us know if you have any other questions and please don?t forget to rate the posting.
Posted on Jan 18, 2007
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
  • 326 Answers
SOURCE: changing an ink cartridge Epson stylus sx105
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX105-_E
that guide shows how to change the cartridges and no you dont have to wait untill they have run out to change the cartridges
Posted on May 15, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
How do i change an ink cartridge out of an epson stylus C4OUX
use a user manual or you can browse in the net thers a step by step procedure that can help you..
May 09, 2011 | Epson Stylus C40UX InkJet Printer
I can't figure out how to get ink cartridges out
Simply lift up the cover and the print head should move to the middle and lift the cartridge slowly and carefully out of the holder.
Aug 14, 2009 | Epson Stylus C40UX InkJet Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Change ink cart
well lift the cover up on the from you will see the cartridges right in the center at the bottom. their will be plastic clips holding them in push on them and that will release the cartridge
Jan 23, 2009 | Epson Stylus C40UX InkJet Printer
Epson stylus c40ux the ink won't print in black or color
If you are still having this problem can you post a new comment, or otherwise we can say this problem is solved.
May 13, 2008 | Epson Compatible Inkjet Cartridges 10-Pack...
Epson Stylus C40UX
did you remove the ribbons from the new carts ?
did you go thro the epson utility to replace the ink ?
Nov 10, 2007 | Epson Stylus C40UX InkJet Printer
Ink cartridge
followed the recommended procedure for changing ink cartridge,however although cartridge moved backwards and forwards it never stopped in the position to change it but remained under the housing on the right side of the unit
Nov 02, 2007 | Epson Stylus C40UX InkJet Printer
How do i take out the ink cartridge
Jan 18, 2007 | Epson Stylus C40UX InkJet Printer
Epson Stylus C40UX InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
