Question about NetGear - WG311 - 54Mbps 802.11g/b Wireless PCI Adapter (TGN1001486P)
Hi i've just installed the netgear WG311 V3 in my PC. The problem is that it detects the wifi, it connects, but it doesn't get the IP, saying that the connection is limted. But i have my laptop connected to the same wifi and no problem. DHCP is enabled and all parameters are fine, so i dont know whats happening. thanks for the answers, and excuse my english because its not my native language.
  • mrpantagruel Sep 27, 2009
    I've also tried not using the WG311 software, using windows, but it wont work.
    It will access the wifi, but it keeps saying that the conectivity is limited.
    The extrange thing is that i use my laptop also with the windows assistant to get the wifi and no problem.
    Im gettin really lost, i'll be really grateful with some help.
    And other strange thing is that my laptop velocity in conexion proberties shows 24 MBPS and when using the wg311 computer also 1MBPS
  • 1,272 Answers
Hi, follow the steps below to configure wireless connection settings on the computer with WG311v3 adapter:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 27, 2009
  • 1 more comment
  • Anand Gupta
    Anand Gupta Sep 27, 2009
    In that case please assign static IP and DNS on the wireless connection.
    Hope this helps. You may also try reinstalling the adapter with the latest drivers which can be downloaded from the NETGEAR support site.
  • mikemuggles Aug 22, 2010
    This was amazing. No one else could fix the problem. This did the trick, but when I started the compter back up, the same thing happened. I can do this everytime, but any way to keep it permenent ? Is this just problem with Netgear ? I had no problems with the adapter card until I changed servers and had to get a Linksys router. 2 laptops and an Ipad connected with no problems. The netgear desktop was the only computer with the problem. Signal found but no connection. Thanks for the help
  • ndamixx Dec 16, 2010
    Yo Anan - You the man!!!!! Straight up - Thanks
    Jammin J
Wna1100 frequently drops ip but stays connected to wifi
Try moving your computer away from other electronic equipment
Keep away from other PC
Oct 08, 2017 | NetGear WNA1100 WirelessN 150 USB Adapter...
Trying to connect my iPhone 4 to my WGT624 v3 router. My iPhone is detecting the network, but i'm getting the message "unable to join the network" .
Hi chaps,
I did two things to resolve this issue
1. Downgrade the router to a lower version.If your router is Netgear WGT624 v3 use this link to downgrade your router
http://www.davejackson.com/life/cant-access-wifi-with-ios-6-on-iphone-with-netge ar-wgt624v3-fix/
(this help to avoid getting a errro message "Unable to join network")
2. Reconfigure you Wifi network by going to setting ---->under choose a network---> others-----> Enter your SSID name (seen at the back of your router) ----->under the security tab selet the same encyrption standard as that of your router which you can see when you log in to the router (usually router IP 192.168.1.1) ---->setup ------>wireless setting----> security option. This one helps you to join your home wifi as soon as you enter your home.
Dec 29, 2010 | NetGear WGT624 Wireless Router
I have installed uninstalled my laptop to the netgear wireless. It won't connect to the secured wireless but only to tthe unsecured It then says TCP?IP disabled for this connection
Hi and welcome to FixYa,
Initially, which is the Netgear, the WiFI / AP router or the wireless networking card of the laptop?
Offhand, that there are at least two (2) networks that could be detected by the laptop indicates that the WiFi is both receiving and transmitting (it works and therefore the issue is settings & configurations). Which of the networks is yours; the secured or unsecured?
Alternately, determine the SSID of your WiFi network and the PASSKEY used or the security system used (if one is used in your system/network). Additionally, are you using the Netgear Smart Wizard Wireless Assistant or the Windows built-in Wireless Network Connection?
For the secured system, use the PASSKEY determined as per above; for the unsecured, it may be employing MAC filter, try manually inputting the IP Address, Subnet Mask and Default Gateway.
Postback result(s) / updates.
Good luck and thank you for asking FixYa.
Oct 14, 2009 | Computers & Internet
I need settin my modem to my pc netgear wg311
to configure the WG311 on the computer, first instll the adapter using the driver CD. follow the step below to configure wireless connection:
1. Double click on WG311 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.1.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
Jul 05, 2009 | NetGear WG311 54 Mbps 802.11g Wireless PCI...
Driver Problem
I M NOT INSTALLED THE DRIVER OF NETGEAR WIRELESS WG311 ADAPTER FOR WINDOWS 2003 SERVER. PLZ. GIVE ME A DRIVER FOR WINDOWS 2003 SERVER
Jan 21, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
NETGEAR WG311
Hi!
I'm sorry to tell you, but Netgear does not have a Macintosh driver for WG11 adapter. It can only work with Windows OS.
Have a nice day!
Nov 30, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
WG311 - Excellent Connection, No Internet
I do it for a living. In my experience with routers in general, they have a tendency to reset themselves with general poweroutages and power surges. I would suggest hard wiring to the router and going into the settings. It might surprise you to find the wep key changed itself during the week. Hope this helps.
Apr 02, 2008 | NetGear - WG311 - 54Mbps 802.11g/b...
Wg311- 54mbps 802 11g/b wireless adapter netgear
you cannot send anything wireless to bluetooth they work on different megahertz, on bluetooth enabled devices can use file transfer
Oct 16, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Computers & Internet Logo
1,224 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
