Question about Sony Televison & Video
Sony STR-K50P will not power on after intense lightening hit
  • 4 more comments
  • gregjones197 Sep 26, 2009
    thanks but the fuse is in tact and ohms properly.
    i have the cover off and teh glass tube fuse is perfectly fine and tests fine
    Thanks. Do you haveinstructions on tracing the components? I have a good multimeter...
    cool, thanks!
  • gregjones197 Sep 27, 2009
    this isnt a tv, it's a receiver
    Hi and thanks. I Don't know where to begin, can u tell me?
    President:
  • 1,884 Answers
It is a fact that during lightening all electronic and electrical gadgets should be unplugged from the wall socket. And I am sorry to inform you that your K50P is burnt. Not completely, but a part of the circuitry is gone. That part can only be replaced and not repaired. So open the back cover and look for burnt.burst chip and replace that module.
Posted on Sep 27, 2009
  • Vinay Tevatia
    Vinay Tevatia Sep 27, 2009
    Open the cover fixed with some screws. and take a peep inside. Try to smell burnt part. And look for odd brown color that indicates burnt component. That module has to be replaced.
  • 615 Answers
If the unit was on or standby during the bad weather then it may be hit with a high voltage and affected the board…you need to do some troubleshooting starting by resetting the system, if not can you open the inside? If you can look for the fuses next to the AC inlet if not look for a noticeable burns or melted parts on the boards, but be very carefully as the unit still will have lots of AC charge, let know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Posted on Sep 26, 2009
  • 1 more comment
  • Norman Al-Anbar Sep 26, 2009
    Then you need to start tracing the board to see any sign of fire and test the components, that if you did the re-setting of the TV. Does your TV controlled by the remote control or from the TV? You may need to reset your control too.
    Let me know. Please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues
    That is what I am working on getting the manf. diagram and specs.
  • Norman Al-Anbar Sep 27, 2009
    Did you start the troubleshooting? keep me informed so I can update the information...Thank you
  • 986 Answers
All components and equipment are designed differently.
The TV is a little unique it requires very hi voltage for the picture tube. and the rest requires a much lower voltage.
plus the TV requires a cable feed and is also plugged into the wall.
If lightening strikes the TV cable outside, all that energy has to find a path to ground, sometimes this path can be through the TV cable through the electronics inside your TV to the power plug to the wall, which has a ground ( do not remove the ground, it will make it worse)
This is one possibility of what happened.
You should check the, or ask the cable company to check their TV cable, and ensure it is properly grounded. but even if it was grounded properly, it will help , it is still not 100%, a direct hit will still take it out. Best bet is to disconnect all electrical appliances during a lightening (thunder) storm.
A surge protector is basically made to handle "normal" power surges within your house's electrical current - it's not made to be a lightning rod.
Your TV was fried because the current from the lightning strike came in through the antenna wire, regardless of whether use cable or a roof mounted antenna. Even though your cable wire is "grounded", it isn't a cure all against all lightning strikes.
Your TV is more receptive to static and electrical charges than a VCR, etc. Although your accessories are ok, the TV couldn't handle the shock (pun intended).
After you replace your TV, whenever a ("big") thunderstorm is heading your way, disconnect the cable hookup from your set. If you're going away on vacation, make sure you unhook your TV too.
  • Roger Campbell
    Roger Campbell Sep 27, 2009
    There is alot more to look at. the fuse or tube is not idication of the unit being good or not.
    Best of luck its fried.
  • 169 Answers
Hello! Hoping for the best here - but your problem may just simply be a blown fuse. Make sure the unit is unplugged, and then on the back, right hand side you should see a small round knob - remove this knob and inside will be a fuse. If it is blown, be sure to replace with the same size.
Hope this helps and good luck! Thanks for using FixYa!
I would like to know what causes Sony str-km2 protection mode after hit by a lightning
There are failed components in the receiver. The protection mode prevents a fire from starting by those failed components. Lightening strike ruins the majority of components on the circuit boards whether you can see the damage or not. Get an estimate from a repair shop. If it comes back as toast, then get yourself a new unit. Damage from lightening is not usually covered by your home owners policy
Feb 02, 2016 | Sony Audio Players & Recorders
I cant power it up when i hit the power button
try to check the plug.,,, unplug then plug it again then try to power it up...
Apr 27, 2011 | Sony STR-DE675 Receiver
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Powers up, all lights buttons seem to work, but no sound
This can happen. Lightening causes static charge that can be picked up by speaker wires. It is possible ONE of the amplifiers has failed.
To check, have the room quiet. Turn on the amp. After 5 to 10 seconds there should be a nice solid 'CLICK' from inside the amp. If there is no click, the unit is in safety mode. You will need a service shop.
Apr 17, 2010 | Sony STR-DE835 Receiver
Hello, I need help with my sony str-de197 receiver. Then I hit power on button, there is a click sound inside the box, but nothing happens, there is nothing on display too. I have checked 2 fuse's, it's...
It sounds like the switch might be OK mechanically but not electrically. Have a look to see if you can check the connections on the switch. Perhaps there is a broken or loose or bad solder joint.
Oct 28, 2009 | Sony STR-DE197 Receiver
Sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Sep 22, 2009 | Sony STR-DB870 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
I have a str dg820 only about 2 months old. Recently went to power up and I get PROTECTOR message and it shuts down. I checked all speaker connections and they appear to be fine. It worked well for two...
Try disconnecting everything (all inputs, outputs and speakers, make sure there is no cable plugged into your unit except the power cord), turn it on, if it still shows the protect message, you have an internal short or a burnt out component inside the unit, possibly a desoldered contact on one of the connectors which generates internal noise of such intensity that it sends the unit into the protect mode.
If, after trying the above mentioned, there's no message, some other possibilities are:
- a bad speaker or speaker cable
- a bad signal interconnection cable
- a fault in any of the other units connected to your reciever/amplifier
Hope you cand find something out...
Good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sony STR-DG820 Receiver
Str-da80es sony receiver
It will have to be looked at . Could have an open connection in the driver ic section or need a driver ic. Worth getting looked at but no quick fixes, sorry
Nov 30, 2007 | Sony STR-DA80ES Receiver
Televison & Video Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
