Question about Homelite Garden
I have a Homelite recirc pump AP-125. Motor runs
I have a Homelite recirc pump AP-125. Motor runs fine but I am unable to get water circulate through it. Suggestions?
    Problem Solver:
  • 15 Answers
Usual if the pump is dry you need to try bleed get some water to the pump. either pouring some in the lift pipe some pumps have a bleed screw to pour into to get it pumping. if it still wont could be the fins in the pump that are not working proper
Posted on Oct 16, 2009
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
Parts for AP 125 water pump (Homelite ) that is no longer being manufactured.
Homelite still has some parts for this pump
go to http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
search for AP125 with no space
pick your model
parts list will come up
Jun 27, 2011 | Homelite Plumbing
Have a homelite AP-125 - UTO1709 F, want to know how far it can pump water uphill
Your best bet is to ask Homelite directly for the pump curve. Since Homelite does not appear to offer it anymore I could not find anyone who published the information, hence the referal to Homelite. A typical pump curve for a small pump like this will show GPM or GPH based on several discharge heights. You do not need to consider the overall run of pipe or hose but only the total change in height. In other words, pumping thru 150' of 3/4" hose up an incline that has a total rise of 12' would end up delivering the GPM for 12' on the curve or something very close anyway.
Contact Homelite here.
John
Jan 04, 2011 | Homelite Plumbing
Timer gets off by hours
I have circulation system on my water heater.
First system gave out.
When taken apart, it was clogged with sediment and couldn't be cleaned.
Put sediment filter on line, and second circulation system works fine, and timer works fine too.
I haven't had timer problem, but have investigated timer motors running fast and slow.
My friend who re-winds big pump motors says homeowner timer motors are engineered for 60Hz.
As long as electric power is 60Hz (60 cycle AC), then motor will keep exact time.
Since your household current is 60Hz and other electro-mechanical timers run correctly, then it's likely timer motor has a flaw or has gone bad.
Grundfos water heater re-circulation pump and timer are sealed unit.
Grundfos manuals do not show parts list or repair steps:
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
It's aggravating when expensive household timers like Malibu power packs and Grundfos pumps are not made to be repaired.
Nov 24, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Motor will not start
For some reason the engine is flooded. To make it start do the following: turn the choke off, hold the throttle wide open and crank it until it starts.Do not push the primer bulb first. It already has more fuel than it can burn. It will smoke more than usual until it burns out the excess fuel. You may also have a carb problem but this should allow the engine to start so it can be diagnosed.
Please rate this solution if it helps-
Mar 19, 2009 | Homelite Garden
Homelite AP 125 two stroke motor will not start after replacing fuel lines. There is fuel coming into the carb and into the cylinder as well. Motor will not attempt to start. Spark plug is new and has...
If you have a two line fuel system make sure the lines didn't get crossed. If they are you could still get gas to the cylinder but not enough. I hope this will of some help to you. Donnyb60
Mar 18, 2009 | Homelite Garden
Not recirculating
"0d" refers to an "open door" problem. Need to chceck the lid switch to insure it is functioning properly.
Dec 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Garden Logo
602 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
