Question about Toshiba 51H93 51" Rear Projection HDTV
My toshiba 51H93 tv won't turn back on after the power dropped the other night. Tried the re-set and all it does is click in the back. Any ideas?
  • Toshiba Master
  • 19,396 Answers
The TV is on protect mode. The clicking noise is the protection circuit that keeps turning the TV off to prevent damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box damaged by the power surge. Check if you get same problem with no receiver box or dvd connected, after unplugging TV.
If that does not work, and you keep having the led in front of the TV on, and tv turning off by itself, that indicates a fault condition.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit. The problem had been caused by power surge.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
In this case the power surge had blown one of the PSU capacitors.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If disconnecting for few hours did not work, try leaving the set unplugged from main overnight, so to ensure that you are draining power from PSU capacitors completely.
Let me know how it goes.
G.
Posted on Sep 26, 2009
Horiz output failure repeatedly?
can you please provide the TV model and part #.
Thanks
Apr 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
I have a toshiba 51HC85. It will not power on the power button is flashing and we smelled a strong oder like something was burning
First is UNPLUG AND DO NOT TRY TO USE THE SET AGAIN.
Have someone who knows what they are doing open set now and look for burnt parts--the smell may lead you to the area where problem is.
Mar 28, 2012 | Toshiba 51H93 51" Rear Projection HDTV
Tv will not turn on even when reset button is pushed all you hear is a clicking noise
You need to replace the power supply on your set, this happen when horizontal output fail.
Dec 18, 2010 | Toshiba 51H93 51" Rear Projection HDTV
Sound went out!
Have the audio signal board replaced. Also make sure ur amplifier is set to the correft output, alth i am sure u have.
May 03, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 51H93 won't turn on **HELP**
Good Day, jsilver05;
That's a very good TV, sorry you're having a problem. I have the same TV.
1. The blurring of the pic may be an indication of a convergence problem.
2. The surge protector is not a fail safe device, it will reduce damage to the TV but will not not 100% protect it.
It is possible that by turning the power off may damaged the already weaken convergence circuit, but more then likely some other electronic device failed.Like a voltage regulator, high voltage device,and etc.
At this point I would recommend that you call a factory authorized service dealer and them come out and give you an estimate, or you can e me if want troubleshoot TV if you have digital meter etc.
Good Luck, big IRISH, mmrkcar@yahoo.com.
Jul 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Tv struck by lightning
This set is pretty common for the regulator IC to go bad. Its inside on the power supply Printed circuit boad assy. It will start with STR#### and have 4 digits after the STR####, depending on the model of the set. Good Luck
Jun 03, 2006 | Toshiba 51H93 51" Rear Projection HDTV
Toshiba 51H93 51" Rear Projection HDTV Logo
254 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
