Question about Foxconn NF4UK8AA-8EKRS Motherboard
Won't boot or start, fans and leds work
I just bought a new NF4UK8AA-8EKRS. Here is the system I have:
939 AMD X2 4200+
768 MB RAM DDR333 (I know, I need more and better)
I have connected everything, checked it twice or three times and when I turn the system on nothing happens. The fans spin and the LEDs light up but the system does not boot, the cd drives do not spin, nor does the HDD. I have tried everything I can think of, removing RAM, reconnecting/changing cables, etc.
I am using a 400W Raidmax power supply and am thinking that this may be a bit underpowered. However, with people I have talked to they have said it should be sufficient. I am hoping the mobo is not DOA.
Anybody have any thoughts?
  • 3 more comments
  • Daners Dec 17, 2007
    no, no beeps. nothing. it seems like there is power to the board but not to any of the computing components.
    I think I came to the same conclusion you about the same time. I realized I did not connect the 4-pin connector. My last mobo only needed a 20-pin and i am using the same case and power supply. i'm at work now but am going to try this when i get home.
    i will definitely respond to the usefulness of the posts when i figure out what is happening. thanks for your help, i appreciate it.
    I removed the video card, ram and plugged in the remaining 4-pin connector. i gradually added components. It powered up and posted when i installed the video card. however, when i plugged in the hdd it failed to post.
    are there settings i can play with on the mobo that will allow the hdd to work, or does this sounds like a power supply problem. ie, lack of juice? is there a way to test the hdd, i do not have an extra lying around. i have a ata133 IDE, not sata hdd.
    This thing is getting weirder by the minute. I pulled everything off the mobo again and began adding until it failed. This time it failed when i attached the video card. A different time it was when I put in the memory and the first time it was the hdd.
    Since it is defferent components everytime I am thinking something is odd with the power supply. I'm going to pick up a new one and see what happens.
  • Daners Dec 20, 2007
    I "fixed" the problem...
    I went out and bought a new psu...Thermaltake 500W. System now runs like a champ. The last thing that needs fixing is to add about 2gigs of memory!
    Thanks for your help, it was much appreciated.
are there setting i can play with on the mobo that will allow the hdd to work, or does this sounds like a power supply problem. ie, lack of juice? is there a way to test the hdd, i do not have an extra lying around. i have a ata133 IDE, not sata hdd.
Posted on Dec 17, 2007
  • 205 Answers
Are you hearing any beeps when you start it up?
  • 2 more comments
  • ohiotom Dec 17, 2007
    The POST (Power On Self Test) beep codes vary from manufacturer to manufacturer, but I think this motherboard/BIOS should give you one short beep to indicate everything is OK.
    I always ask this question and sometimes I get yelled at...did you plug in both power supply connectors. There are two, one is long and rectangular, and the other is a smaller square shaped connector. The first time I built a system I did not realize there were two.
    Assuming you do have both power cables connected, I would disconnect all the peripherals (hard drives, CDROM/DVD) and pull out all the RAM and try to power it up. If you don't get any beep codes there I would pull the CPU and try one more time. If you don't get any beep codes then either the motherboard is dead, or you have a power supply problem.
    Good luck.
    By the way, more than getting a positive or negative rating I just like to know if you've solved the problem. Please take a moment and let us all know how it goes. In this way, other people will be able to read this post and see how you solved your problem.
    I just downloaded the manual for this motherboard and it definately has the 4 pin 12V CPU power connector. I hope this fixes your problem.
    Unless there's something wrong with the power supply, I think it should be enough to run the motherboard, video card, and HDD.
    I'm at a loss to understand why it won't get through the POST when the HDD is attached.
    Have you tried both of the IDE connectors for the HDD?
    If you cannot get into the BIOS when the HDD is plugged in then I would disconnect it and boot into the BIOS to see if anything looks wrong for the IDE setup. I would go ahead and check this, but I can't think of any setting that would prevent the POST from at least giving you a beep code error...
    Let me know what you find.
  • ohiotom Dec 18, 2007
    Sounds like it's worth a try. I can't think of anything else at this point. Let me know.
NF4UK8AA-8EKRS motherboard no longer sees either of the SATA hard drives. Any thoughts?
Hello here is the homepage:
Try to enter the bios, and look for the harddrive settings.
The driver is needed for the pci card, do you have them ??
Your friend could have damaged the mainboard.
Good luck
Jan 30, 2013 | Foxconn NF4UK8AA-8EKRS Motherboard
Winfast NF4UK8AA shutsdown and freezes by itself
i install new window xp and i could not make sound working i dont know what sound card has motherboard GX280
Mar 13, 2009 | Foxconn NF4UK8AA-8EKRS Motherboard
Foxconn NF4UK8AA-8EKRS doesn't recognize CPU
Smithbrother is right...
the file you need is here:
You'll have to get yourself a BIOS flash utility. There are some simple, good boot disks for that here:
then you'll need to boot to that disk (not into Windows), and run the flash utility provided at the previous link. Once your BIOS has updated itself, you should be good to go.
This is a known issue with early BIOS revisions of your board.
Jan 17, 2009 | Foxconn NF4UK8AA-8EKRS Motherboard
PC wont Boot/start
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
Aug 27, 2008 | Computers & Internet
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Sep 03, 2007 | Mach Speed (MSNV-939) Motherboard
Could be one of three things, either your motherboard is faulty (check the capacitors for bulging) and is not getting the power to the processor, the processor itself has faulted, or it's simply a flat cmos battery, as this can cause none starters.
May 18, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
PC wont Boot/start
try another graphics card if you have a working spare
Feb 16, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
It sounds as if you have a flat CMOS battery, remove and replace. To delete the password and bios settings locate 'JBAT1' terminal on motherboard and put jumper from pins 1-2 across 2-3 for a few seconds and then back to pins 1-2. You will have to reset time and detect drives in standard CMOS settings.
Jan 09, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Foxconn NF4UK8AA-8EKRS Motherboard Logo
275 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
