Question about Kenmore 62702 Microwave Oven
Kenmore 363.62709200 turns on and spins, but doesn't heat food
  • 909 Answers
The most common problem it seems on the microwave is it is working but no heat. That indicates a problem in the power circuit. 90% of the time your capacitor and its associated component the HV diode need replacement. Once replaced, retry. If still not heating, changing the magnetron will be needed. The only way to be sure is if you are offe with testing equipment to know which of the two to replace.
Posted on Sep 27, 2009
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: How to fix an Emerson microwave 8992RD that
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on May 08, 2011
hbsurfdawg
  • 95 Answers
SOURCE: My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Posted on Nov 22, 2011
Kenmore microwave not heating food
bad magnetron... or a bad door switch check the door switches 1st
Apr 10, 2014 | Kenmore Microwave Ovens
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 02, 2012 | Sharp Microwave Ovens
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
e
Nov 22, 2011 | Microwave Ovens
How to fix an Emerson microwave 8992RD that carousel doesn't turn and doesn't heat your food..
heatman101
May 08, 2011 | Emerson Black Microwave Oven
Kenmore microwave stopped heating
simply stated.. if it fails to cook.. you may have either a bad magnetron tube ( that's the part that generates the microwave energy that cooks the food) or the filament transformer feeding that magnetron is bad. In either case.. you're probably better off replacing the entire appliance than repairing it.. Hope that helps...
Aug 30, 2008 | Kenmore Microwave Ovens
Microwave just quit working
Hi , Open the cover unsscrew it , be sure to unplug power ,if you have continuety tester , test the fuse if open replace it , is also availble in appliance parts center near you.
Feb 13, 2008 | Kenmore 62702 Microwave Oven
Kenmore 62702 Microwave Oven Logo
273 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
