Question about Saws
Need to change the blade on a craftsman 10 inch miter saw; the bolt won't loosen
  • 142 Answers
Have you checked to see if it is a reverse thread bolt.
I know on my Dewalt saws they are
Look at the bold or washer and see if there are arrows showing a reverse turn
Posted on Sep 26, 2009
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
How do you change the blade in a Ryobi 2000 watt mitre saw?
Ihave the same saw and i like it a lot. There is awrench that clips in near the handle that fits the bolt also there is a lockon the front of the saw under the trigger that needs to be press in this will lock the shaft . The bolt is left handed so you have to turn it clock wise to loosen its the oppisite a normal thread so it dosn't loosen whale you are opperating it. Pull back the blade gaurd loosen the bolt remove note the way the washers come off theres only way they fit so look at them as your removeing them . Put the new blade on the outer washer push the shaft lock bottem tighten and its ready to use.
Jan 08, 2011 | Ryobi 10 In Miter Saw With Laser
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Sep 10, 2010 | Makita 10" Miter Saw LS1030N
On a 10 inch power compound miter saw, I need to replace the blade. Does the blade bolt have left handed threads? Thanks
Place a finger nail in the thread near the end ot the shaft. If when rotated CW it comes off the shaft it is a left hand thread. My 10" Craftsman radial saw has a left hand thread on the blade shaft.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Craftsman Garden
I have a craftsman table saw model 137.248830 and the blade is out of square with the miter. How do I adjust it?
You should have 4 bolts holding the trunnion on to the table, just loosen these bolts up a little, tap the trunnion with a hammer, the right way, put a straightedge on the blade fully extended and measure across the table to a dado slot, front and rear, tap it till it is exact, tighten bolts and check again. This should do it. You can check your fence the same way. hope this helps.
Jul 26, 2010 | Craftsman 10" Table Saw
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
I have 1 10 In compound miter hexbolt will not loosen and lock will not hold. Is it possible that the bolt is a left thread?
most mitre saw bolts that hold blade are left hand thread. If you overtightened you might have to use extra force to loosen, on occasion I have had to use an impact wrench to loosen.
Jul 13, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Saws Logo
98 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
