Question about HP LaserJet 2840 All-In-One Printer
2840 Hp Color laser jet displaying Scanner error 05
    Genius:
  • 1,089 Answers
The book says to try the old power off and on. And then replace the scanner assembly and then the formatter.
Personally, I would try the formatter.
Posted on May 17, 2010
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I have an HP 2840 color laser jet that keeps presenting a Scanner Error Code 6. Might anyone know if and how I can repair this on my own? Thanks a ton! Mike
replace optical scanner assembly..(a unit located in flat bed scanner with florocent lamp moving left to right while scanninf & copying)
Sep 17, 2011 | HP LaserJet 2840 All-In-One Printer
Hi, I have aproblem with the HP Laser Jet 2840 all in one.. display shows Scanner error 3. i tried several times switching off and on but it does not help. However, each time i switch it on, the scanner...
You are going to have to have it looked at by a trained printer tech.
Just from your description, it sounds like the scanner/copier assembly needs replacing.
Aug 03, 2011 | HP LaserJet 2840 All-In-One Printer
HP 2820 scanning steps
http://www.google.com.ph/search?q=how+to+use+scanner+in+HP+LaserJet+2820+Printer&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox
go to this link above, on the bottom you can see HP Color laserJet2820/2830/2840 userguide HP color Laser Jet, left click on this file and you can download the user manual of this printer.
Nov 27, 2010 | HP LaserJet 2820 Printer
HP color laser jet 2840 feeder is broken
something might be blocking the light from the scanner lamp to fall on the originals. Try cleaning the glass covering the lamp.
May 23, 2009 | HP LaserJet 2840 All-In-One Printer
JUST CHANGED TONER...GET RESPONSE TO REPLACE SUPPLYS
While holding down the Check-Mark key turn the printer off then back on.
Jan 22, 2009 | HP LaserJet 2840 Printer
Hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Dec 15, 2008 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 All-In-One Printer Logo
211 people viewed this question
Seeker5211
Seeker5211
