Zanussi ZWF 1621W - fails to spin
Zanussi 1621
Fills O.K.
Reaches end of wash cycle.
Motor is working up to this point.
Then beeps ''end'' and
Stops before going onto spin.
I don't _think_ it's pumping out, but I'm not sure. Pump is my first suspicion.
I have cleaned out the pump filter and given the board/receptacle contacts a once-over with sevisol.
TIA
    Scholar:
  • 83 Answers
Unfortunately this fault sounds like it could be the timer, the PCB board or even the motor. A pressure switch fault or blockage in the pressure bottle would cause the symptoms that it washes and distributes perfectly OK, but just wont do the fast spin. It doesn't sound like the case here. The jerkyness of the motor implicates one of the above causes. It's possible for badly worn carbon brushes to cause a jerky motor. If you had water on the electronics too, there's no guarantee it hasn't caused some problem. It doesn't look promising I'm afraid.
The "two air pressure sensors mounted at the top of the frame connected by pipes to the nether regions" must be the pressure switches.
Posted on Sep 28, 2009
  • 4 Answers
SOURCE: zanussi zwf 1415w become very noisy when it is running all time?
you have to call a technician to check the drum bearing
Posted on Jun 04, 2008
  • 67 Answers
SOURCE: Zanussi ZWF 1621 S Front Load washer - LED Lights are not lit up
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • 62 Answers
SOURCE: zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Posted on Oct 20, 2008
  • 62 Answers
SOURCE: washing machine will not start
I don't think this is a GE model #, but any who, if you hear a humming <water valve sol> the product valve is not getting water to it, first, don' laugh, make sure both plumming valves are on..
If they are off and no one knows how they got turned off, it falls under the old "****-happens" deal !
Posted on May 21, 2009
apart4u
  • 213 Answers
SOURCE: how do i remove the door seal on the zanussi zwf 1220s
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Zanussi machine washer. ZWF 1000M The wash button is red. The rinse button, spin button, and power botton is flashing red. This happened several minutes after tuning oN the 30 min cycle.
According to your description it is a failure E9- motor is not working. The temperature rises too high. The motor cut off for heat safeguard (Harness failure, PCB failure).
Dado
Apr 06, 2016 | Zanussi Washing Machines
Remove knobs zanussi zwf 1621 w
some timer knobs had pop on front cover on knob the 2ba nut on inside of same.
Apr 09, 2015 | Zanussi Washing Machines
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
Washing machine will not start
May 20, 2009 | Washing Machines
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
223 people viewed this question
Top Washing Machines Experts
