Question about HP Computers & Internet
HP dv5400 laptop and external power source won't power up
We have HP dv5400 laptop and external power source will not power up laptop. It fell while charging and bent the power cord. Any ideas?
    Problem Solver:
  • 14 Answers
Either your AC CORD or POWER JACK is BAD... Check if that's the case, if not, the worse senario is that the charging port can be shocked, which you will have to replace the motherboard...
Posted on Sep 26, 2009
My dashcam won;t charge
laptops do not have dash cam's and if they do the power comes from the laptop not an external source
Feb 07, 2016 | Computers & Internet
HP pavilion HP Pavilion 15-p087sa laptop is not powering on and making ticking noise.
Hello
It's might be the fan that's making the noise or can be something worse then that, I would recommend ask them for repair if it is still under warranty.
Dec 03, 2014 | HP Pavilion Computers & Internet
My hp laptop won't power up. I bought a new power cord and connected to my laptop and the power light won't come on, so what esle can i do to get power to my laptop?
Have you followed the Guided Troubleshooting steps provided on the HP Support web site?
These will take you through a series of checks and decisions to try to isolate the cause of the problem along the following lines:
1. Are you sure you are plugged in to a good power outlet - can you plug a lamp in and does it work?
2. Are you sure that you are using the right power adapter for this laptop, is it the original HP block supplied with the laptop or is it a replacement - if the latter, then does it supply the correct output voltage and watts required by the laptop.
3. Are you sure the problem is not just the laptop display being dead, i.e. have you tried attaching an external display, do you get any leds light on the laptop for power, disk activity etc?
4. Have you tried removing the battery from the laptop and connecting the power adapter with it removed to prove that the battery is not preventing the laptop from powering on?
5. Have you disconnected all external devices from the laptop, in particular docking station, printers, USB devices etc to ensure that no external device is preventing it from powering on?
6. Do you have another power adapter that you can try using - are there any lights on the power adapter to show that it is working?
Jan 05, 2012 | HP Compaq 6820s Notebook
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
My HP DV9740US laptop will only recognize one external hard drive at a time. When i plug in another external hard drive it'll make the sound that it's recognized but won't show up in My...
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Pavilion dv4000 PC Notebook: I want to use power point using hp laptop and acer...
you need to hold down the fn key then hit the f4 key to switch to external source.
May 16, 2010 | HP Pavilion dv4000 Notebook
Hewlett packard 6735s power up
Your battery is critically low. Didnt you recharge your battery? Try turning it on with the external power source connected.
Jan 14, 2010 | HP Compaq 6735s Notebook
HP Pavilion dv5003cl won't turn on after small fan falls on it.
If the fan fell directly on top of it then it could have destroyed your lcd display. Power down the laptop completely, plug external monitor into vga port on laptop, power on laptop. If you have video on the monitor then you would likely need to replace the screen. If you send it in to get fixed it will cost a lot of money. You could do it yourself if you are comfortable with that type of thing.
Sep 15, 2009 | HP Computers & Internet
Computers & Internet Logo
224 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
