Question about Dell Inspiron 700M Notebook
Wifi will not connect. Worked fine. Now the wifi light does not come on and it does not connect to the internet. No changes to the computer
  • 3 more comments
  • rsmasker Sep 26, 2009
    I have a dell 700M laptop. My Intel Pro/Wireless 2200BG card will not turn on. I press FN-F2 to turn on my wireless manually, and when I do this the wireless does not turn on. I tried turning it on through the Intel interface, through My Network Connections, and every other conceivable way. The wireless card is enabled but it says that I have to turn the hardware radio switch on manaully (function F2). The function key works fine so do you think the F2 key is malfunctioning? Thanks.
    This is a insprion 700m. It does not have a switch like the one you show. To turn on the wireless card all you do is press Fn-F2 and the wifi light comes on and it connects to whatever wireless is availible. However, now all of the sudden when I press the Fn-F2 button, nothing happens. The light does not come on and I do not connect.
    How do I go about connecting to the internet in order to download the drivers. I am e-mailing you on my desktop because the laptop in question will not connect to the internet. I tried running an ethernet cable to the laptop but I cannot connect to the internet with that either.
    Installed the drivers and it still does not work.
    I have an inspiron 700m laptop. When I press the Fn-F2 bottons to turn on my wireless card nothing happens. The wifi light no longer comes on and it does not connect to the internet. I have made no changes to the computer. I have logged onto dell and downloaded the drivers again. Doesn't work.
  • 453 Answers
The wireless switch is a type of switch which is located on the sides of the laptop. It is a type of sliding switch which looks like this.
Look for this and place it in on-position.
Dell has a software called Dell Utility in the Programs. Look for the same and look for Radio on /Off check box. Sometimes the radio tends to turn off automatically because of which you may not be able to connect to internet.
Posted on Sep 26, 2009
  • Sai Kiran Camsarapalli Sep 26, 2009
    May be you need to try and reinstall the drivers for the wireless card from the Dell's support website.
    Click on
    www.support.dell.com
    Choose Drivers and Downloads and choose your model or you can enter the service tag of the system stuck beneath the system.
    Choose Ethernet and wirless drivers for your system and install the same. This should resolve the issue.
    Kindly comment.
    You can download the software on your desktop and save anywhere in the desktop. Connect Flash drive and save it into the flash drive. Now connect the flash drive to your laptop and install the same
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This is happening not due to a software issue but due to hardware issue. The physical connections inside your laptop on the WiFi card are loose. Or it may have happened due to a loose connection between the WiFi card and motherboard. Try and open your laptop and check for the physical connections inside the laptop. Please see this disassembly procedure--
  • Turn off the laptop. Make sure the laptop has been shutdown completely and that the computer is no longer plugged into a wall outlet. Remove the battery. If you have recently been using the computer, wait at least 3 to 4 hours before disassembling it to reduce the amount of static discharge.
  • Open the screen. Open the screen up completely so that the laptop lays completely flat. Make sure it is securely positioned on a flat, hard surface.
  • Remove the keyboard panel. Pry off the strip of plastic located directly above the keyboard. This piece is covering several screws attached to the motherboard, and removing this first is the easiest way to get to the motherboard components and the cooling fan.
  • Remove keyboard screws. Use the Phillips head screwdriver to remove the four screws holding the keyboard down. Set the screws aside in a safe place.
  • Remove the keyboard. Gently tug on the keyboard and lift it up to reveal the ventilation fan and the tab holding the keyboard to the motherboard. You can now clean the ventilation fan if you need to.
  • Begin disassembling the motherboard. Use the Phillips head screwdriver to unscrew the large screw located in the center of the motherboard. This screw is holding two large metal plates covering the motherboard together.
  • Remove the motherboard cover plates. Gently lift the detached plates off the laptop and set aside in a safe place.
  • Remove the cooling fan. Use the Phillips head screwdriver to unscrew the cooling fan panel; you will need to unscrew three screws located around the fan, then lift the cooling fan out of its holder. You can now clean out the cooling fan if necessary.
  • Close the laptop. Place a clean, thin dishcloth over the motherboard and gently close the screen. Turn the entire laptop over so that the base is now facing up and the battery is facing away from you.
  • Unscrew hard drive and memory components. The hard drive is located in the bottom right hand corner; the memory unit is located in the center of the laptop. Unscrew both of these by removing the small screws at the bottom of each unit and remove the covers on each.
  • Remove WiFi cover. The WiFi unit is located at the top left of the laptop; remove the two screws from this unit and lift the WiFi cover off the laptop. Check for all the connections. Reassemble and check.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • 360 Answers
Go to the control panel-network connections and see if your wifi is there. If it is disable it and then enable. You should be ok after that. If not then you need to download the software for it. Try it now and if it don't work post a comment and I track the software for you.
Why doesn't my digiland tablet connect to the internet at work. The wifi info says it's connected and excellent! Works fine at home. I also use a Nook Tablet and it connects fine!
Usually with 'work wifi', or any public hotspot, merely connected isn't enough. You have to open your browser and connect to a new page. It has to be something that isn't in history or cache. I favour ba.com because it is short. Accept the Terms and Conditions and click Connect. Once the page refreshes, you are connected.
At home, you are connecting to your own internet and not through a third party company like Datavalet, Boingo or similar. There is no terms and conditions to accept, so you are immediately connected.
Feb 14, 2016 | nook tablet Tablets & eReaders
How do I fix losing internet connection.
Is the Acer Aspire the only computer that lose its wifi connection on the wifi or do you have an mobile or another computer that works fine?
Dec 05, 2014 | Acer Aspire Computers & Internet
Wifi connects just fine but when I open my browser it disconnects
Does your neighbor know that you are using his connection?
if not, maybe he changed his password, and you cannot use it anymore, so do ask neighbor first if anything changed ;)
Mar 23, 2014 | Computers & Internet
No internet connection after uninstalling norton
hi there.
you could try and do a restore to the last date it all worked fine.
or see if starting up in safe mode might help you find out.but i would try the restore first.
Nov 17, 2017 | Norton Internet Security 2005...
Can't upload files or send emails via wifi with dgn1000 router
Has this ever worked and now something's changed, or have you never been able to make it work, please?
Nov 29, 2017 | NetGear DGN1000 Wireless Router
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
Ipod touch will not connect to belkin wireless router.
If your Ipod touch will not 'find' your Belkin N router - or it did and then vanished forever try this- it worked for me.
1.Turn wifi off on your computer, ensure you have the latest firmware on your router,reset the router to factory default.Do this using a wired connection from the admin page.
2. Change the SSID name from what it was previously say from Belkin xyz to my router.
3. Power down the router wait about 30 seconds then power it back up.
4. As you reset to factory setting you will need to put in your internet access info again - do this from the admin page. Also set up your security at the same time.
5. Restart the router from the admin page.
6. Unplug wired connection start wifi and connect to your computer -make sure that you have full internet access from you computer - dont forget you need to connect to the newly renamed router.
7. Take ipod and make sure wifi is off.
8. Clear network settings.
9.Turn wifi on and it should find your newly renaned router - join and enter your pass key.
Why it does it I have no idea neither do Belkin or Apple but it worked for me - a trial and error solution !
Good luck
Mel
Jan 25, 2010 | Belkin (F5D7230-4) Router (587009)
Cannot turn on wifi on T400. Intel 5100 card
Is the "broadcast-tower" light on (the leftmost icon on the lite-bar below the screen)? Have you got an available/working WiFi router? Have you been able to choose a network to connect to? My T400 works fine when all the above are enabled..
Jun 18, 2017 | IBM ThinkPad G41 Notebook
WIFI does not work: internal error 00000001
its a sony problem its just what it says when it cant pick up a connection, if you want to get rid of it then update your psp.
Feb 16, 2008 | Sony PlayStation Portable (PSP) Console
Dell Inspiron 700M Notebook Logo
843 people viewed this question
Alun Cox
