Question about Dell Computers & Internet
Dell studio 540 I get the boot screen: hard drive self monitoring system reportede that a parameter exceeded it's normal operating range
Maanita
  • 1142 Answers
SOURCE: Dell Dimension 5000
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
Posted on May 04, 2008
dodgecharger
  • 254 Answers
SOURCE: i just replaced my hard
New hard drives don't have an O/S installed, so they just be prepped and the O/S reinstalled, along with your applications.
Does your computer "see" the new drive? If the drive was properly connected, a modern computer will automatically detect it, and you shouldn't need to do much if anything in BIOS.
There is a key sequence to get into the BIOS setup, differs from computer to computer.
Assuming the computer detects the drive, the O/S install should partition, format, and install. Some SATA machines may not install Win XP without some additional work. Do you have the CD(s)/DVD(s) that came with your computer? If so, they should have all the proper drivers (including for SATA interfaced drives).
Hopefully this will help.
Posted on Dec 23, 2008
jell587
  • 447 Answers
SOURCE: screen comes up stating; self monitoring system
The error refers to the SMART system (read more about it).
Your hard drive may be getting ready to fail or you may have received a false error message (which can occur). If possible go into the bios/CMOS and disable the SMART system so that you may be able to boot normally. Once booted you need to make a backup of your data immediately.
If you are unable to boot the machine even after disabling SMART you may need to replace the hard drive and hook the old one up either externally (the preferred method) or as a slave so that you may backup the data on it.
Posted on Mar 02, 2009
pontelemon
  • 538 Answers
SOURCE: How to restore data files from a dying hard drive?
You'll need any of this.
I used SnapShot before. Very easy.
Posted on May 23, 2009
  • 3940 Answers
SOURCE: can't access hard drive getting IDE master hard drive SMS mess
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
Posted on May 28, 2009
Parameter out of normal operating range, computer will not boot up
Probably need to replace the hard drive and reinstall your operating system. Can you boot from a cd? Do a hard drive test and post the results.
Feb 24, 2014 | Microsoft Windows Vista Home Premium with...
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
Consumer IR Device problem
This is a SMART warning and it means that the hard drive in your computer is starting to show signs that it may fail. It is highly recommended that you make a backup of the things on the drive that are important. IT is also advised that you make get or find the recovery disks for that computer because when it fails you will have to get a new hard drive and they are blank.
Nov 21, 2017 | Dell Inspiron All-In-One Computer
I get a screen which states a parameter has exceeded its normal operating range - which may or may not indicate a potential hard drive problem
This error message indicates the video setting of your computer has exceeded the operating range of your monitor. You need to reduce the screen resolution and/or the monitor refresh rate.
This is not a hard disk problem.
May 07, 2011 | Dell Studio 540 MT Pentium DualCore E5300...
My dell Optiplex GX270 will not start up. it gets to the microsoft xp loading screen and it begins to load but then it restarts. it gives me a message "the primary IDE master hard-drive self...
Sad to say, you need a hard drive. The clicking sound you're hearing is typical of a drive that has gone bad. The monitoring message you see is from the motherboard's SMART monitoring, which checks several drive parameters and tells you when something is out of normal range. Often this gives some advance warning of a drive going bad, but this time it's just another sign the drive is already bad.
Installing a new hard drive is quite simple, with only two cables to plug in and some screws holding the drive in place. You will need to reinstall Windows and your applications since the new drive will be blank. There isn't anything you can do to repair the bad drive. If you have data on the drive that you don't have backed up on some other medium and you must have, there are companies that offer data recovery services. Just be aware it can be expensive.
Sorry I can't give you better news, but thanks for using Fixya.
Nov 11, 2010 | Dell OptiPlex GX270 PC Desktop
Can't access hard drive getting IDE master hard drive SMS mess
May 27, 2009 | Dell OptiPlex 170L PC Desktop
Screen comes up stating; self monitoring system
Mar 02, 2009 | Dell Inspiron 530 Desktop Computer
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
IDE MASTER DRIVE ERROR
Sure sound like you hard drive is starting to have a problem. I would clean and defrag it after backing it up. start- my computer- right click on hard drive-properties-disk cleanup/  After that then 'tools defrag hard drive. then run scan disk
Jul 14, 2008 | Dell OptiPlex 170L PC Desktop
Computers & Internet Logo
145 people viewed this question
Alun Cox
