I have a honeywell thermostat i am not sure what kind it is just square with an up and down arrow...my om has shut it off and I want to know how to turn it back on because she is gone and it is burning up in here!
  • 358 Answers
Turn the lever to cold and the other one to auto and with arrows you'll set the temperature. If it's a digital thermostat it'll take a few minutes to start. Also make sure the a/c breakers are on.
Posted on Sep 27, 2009
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Oct 05, 2009 | Honeywell Electronic Programmable...
Ac will not kick on
That is just a change filer signal. It does not chut your ac down to clear some tstats you push up and down keys at same time. I need to know what kind of tsta you have and I can tell you how to clear it. Russ
Jul 23, 2009 | Honeywell Programmable Thermostat Heater
Wiring honeywell to old landis thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jul 08, 2009 | Honeywell Heat/Cool Thermostat
BOUGHT AND REPLACED A HONEYWELL ROUND THERMOSTAT AND THE HEAT WILL GO ON BUT WILL NOT SHUT ITSELF OFF WHEN THE TEMPERATURE GETS TO THERE. IT KEEPS RUNNING TILL I SHUT THE THERMOSTAT OFF. I FOLLOWED THE...
look at the old thermostat and in the middle of it theres a arrow that is pointing at numbers that is called a heat anticipator. then on the new thermostat make sure that its set the same.
Feb 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Nov 13, 2008 | Honeywell Programmable Thermostat Heater
Honey well thermostat
Call a reputable serviceman to change the thermostat and tell you about your system, and if you can have it repaced "free" before the clause kicks in!(down here ,we have from 10-14 days to find out if something is wrong for the realator to repair--or replace or adjust the total home sale.. (oklahoma )!
Sep 09, 2008 | Honeywell Programmable Thermostat Heater
Honeywell t8601d showing a square symbol error - in past this has indicated low refrigerant. Tech came out, said need to replace thermostat, as compressor would not start, but if manually connected wires,...
There is a sensor that shuts the compressor down when the freon (refrigerant) is low. The tech probably "shorted" out this sensor. If the unit went on when he did this, the charge is low.
Jul 07, 2008 | Honeywell Heating & Cooling
Adptive intelligent recovery
On the Pro4000 model you hold the 2 arrows until you go into setup mode. Then arrow up ONLY til you get to option 13. The display will read 13 and 1, press the DOWN arrow and it will read 13 and 0. This turns off Adaptive Intelligent recovery. Now hold the 2 arrows til you see the normal display screen. You are done.
I just did this with a Honeywell tech rep on the phone.
Nov 15, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
