Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi wd 52525 chasis cooling fan
I need to replace the chasis cooling fan on my mitsubishi wd 52525 dlp.
It seems that part number 299p103050 has been discontinued.
Andrews electronics wants $188 for a replacement. I think that that price is high for an ordinary 12v dc fan.
Im thinking of replacing this fan with a 12v fan that is used for a computer case.
does anyone know if this may work?
Does anyone know of another source for this fan. Mitsubishi does not answer their phone or fax.
    Problem Solver:
  • 23 Answers
Take fan out and go to Microcenter or radioshake for about $10
Posted on Mar 05, 2010
That should work. but make sure that the voltage form the wires are DC and not AC. In addition, depending on the original fan the RPM's maybe different. If you do replace with a computer fan just make sure the flow feels reasonably good.
Posted on Dec 24, 2007
  • 4,402 Answers
Try ebay
Posted on Dec 18, 2007
Mitsubishi wd60735 code 37
A 37 error code means one of your fans is bad. It would either be the DMD fan, or the lamp fan. Take the back cover off of the set and tape down your lamp safty switch. Turn the TV on and see which fan is not working, and replace.
May 17, 2012 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp projection tv timer flashing green unable to reset TV
call Mitsubishi, 18003322119. They seem to know this is a ubiquitous problem with these sets, and seem willing to cover parts (all new electrical chasis), but not labor. Have to have an authorized repair tech look, verify problem, fax info to Mitsubishi, then will send in chassis for rebuilt one. Cost from what I've seen runs $300-400 in labor. Stinks you have to pay any, since Mitsubishi used bad capacitors in making the T.V. in the first place.
Nov 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dlp wd 62725 will power up then when i turn it on makes a noise
One of the cooling fans is bad. You have to isolate which one & replaced it w/ oem mitsubishi part. Some of these arew not accesable by a consumer. You need a tech to fix this unless its the chasis fan, thats easy.
Jan 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD 52525 mitsubishi - how to I get a copy of manual and check balist - or dm board?
you can get the service manual at the following link. Its under the mitsubishi category listed as the V26 DLP service manual.
Sep 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Electrical chasis cooling fan for Mitsubishi wd 52525
There are several Parts Houses that carry this part. The one I think that is the easiest to deal with is Andrews.
The URL is:
Can't find it there, reply to this post and I will respond.
Dec 14, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
578 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
