Question about Samsung HCN653W 65" Rear Projection Television
I have red streaks going across my screen and perfect focus will only go to 25%
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad convergence board
probably this one here make sure before you buy
checking this is the correct one for your model, samsung has a few version of this set
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Posted on Sep 27, 2009
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
We are having trouble while printing bar coded labels, there are streaks going across the label what can stop this from happening?
If streaks are perfectly vertical and always present, probably your printhead is scratched and needs to be replaced. Unless the streaks are diagonal and intermittent - then you need adjustment for ribbon wrinkle.
Printheads
Oct 01, 2010 | Datamax M-Class M-4208 Printer
Lot of red streaks across screen.Try to adjust convergance, blue aligned perfect but the red didn't
possible fuse. if the red is curved or bent, if the red is straight try covering tv with blanket so the sensors get a good reading. again if the red is bent, and fuses are good..... bad convergence ic's.... local service center
Nov 24, 2009 | Hitachi 43FDX01B TV
Picture looks curved on screen not flat and straight across. Images have pink and green streaks on them. We lined up the convergence as best we could but its not perfect and the screen still looks curved.
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
Oct 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
316 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
