Question about Mtd 22" Yard Machine Push Mower
How do I change the throttle cable on my yard machine lawnmower?
    Novelist:
  • 168 Answers
First thing you have to do is remove the little black box on the handle with a bolt going thru it. Once, this is done you'll see that the cable will only fit in there one way. Good luck
Posted on Oct 09, 2009
Lawnmower
It sounds like the throttle cable has moved and in doing so lets the engine run at full revs, follow the cable down the the carb on the engine, the outer part of the cable will be clamped with a bracket and screw, you need the slacken the screw and push the outer cable forward the reduce the tention on it.
Jun 18, 2012 | Black & Decker Garden
The lawnmower is revving really high, I'm thinking
Sounds like you are going to have to take a look at the linkages. To do this you will need to remove the air filter and then the air filter housing. Probably have to remove the shroud (cover on top of engine). Now you should have a good look at the throttle linkages. Try to moved them to see if they are stuck. You will be pushing against spring pressure so expect some resistance. Just checking to see if there is freedom of operation to tell you if stuck throttle linkage. If stuck you will have to determine if in carb. or not and then repair.
If this is really helpful, please rate.
Jul 12, 2011 | Mtd Yard Machines 158cc Briggs and...
How to speed up motor on yardman self propelled lawnmower
You could disconnect the governor linkage at the carburetor and just connect the throttle cable (if it has one) directly to the butterfly plate on the carb. Aftermarket throttle cables (one size fits all) for push mowers are available. If you go this route, be careful not to over rev the motor (esp. when not under load) as you could possibly throw a rod or float a valve.
Aug 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Riding lawnmower wont start
yeah i do... you need to remove the cables and hook them up the right way.. the red cable to positive post ( + ) and the black cable to the negitive post ( - )..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Lost spring to carburetor mtd lawnmower
you can go down to any napa or hardware store and pick up a light small spring about 1/4 inch maby 2 to three inches long atach it to the throttle and your ready to go
Nov 08, 2009 | Mtd 22" Yard Machine Push Mower
I can't get my lawnmower to start. I tried changing the throttle and everything...where is the choke so I can adjust it?
The choke is supossed to be closed when you lift thr throttle all the way up it it doesnt close all the loosen the cable I beleive its 5/16 make sure your throttle is all the way up loosen the throttle and pull on the cable you will see the choke plate close then tighten the throttle back up when you pull the thottle up all the the plate should close
Nov 05, 2009 | Craftsman Garden
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
If the oil in my lawnmower is overfull, how do I fix this?
should be a drian plug on the bottom of the mower engine, just drain and tighten up the plug and refill. they usually hold about 16 to 20 ounces of oil. Go buy briggs and stration oil at walmart or kmart just the right amount
Jun 13, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
601 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
