Question about HP Computers & Internet
I turn on my pc all fine screen says no signal help please
  • 40 Answers
The cable is not good... or not receiving a signal from your graphics card
either the connection on the back of the monitor is not tight enough
the actual video cable could be bad
the plug to the graphics card may not be tight or in the wrong output port
the bios could be set wrong for display to the graphics card.. check with your hp website for the correct bios settings for an add in video card
or the graphics card could be bad
Posted on Sep 29, 2009
  • 63 Answers
There is no connection between the monitor and the video card. Make sure the cable is connected well on both sides. If it doesn’t help, most likely you need a new video card.
Posted on Sep 26, 2009
    President:
  • 1,015 Answers
Verify that the VGA cable is fully seated and connected. If you can test the computer on another monitor or test another computer on that monitor. Are you getting any video display on the monitor? Does it display the start-up screen then goes away when windows starts? If so start the computer and press F5. A menu will come up and select to start computer in VGA mode. This should bring up windows so you can change the screen resoloution to something the monitor can handle. If the computer does not display anything and the monitor is testing good then the on-board video or video card might be faulty. You could change the video card if it has one or add one to the system if it has on-board video. You could also try re-setting the BIOS jumper to clear the cmos or pull out the watch battery for 20 seconds. Another thing to try is to disconnect all hardware...cd-rom, hard drive, floppy drive, and memory dimms and see if it boots up with display. If that works the you will need to re-install each piece of hardware one at a time and re-boot until the problem happens again. Once it does that is your problem device. You could also try swapping out the power supply and see if that is the cause of the problem.
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
I just got a used 2 port KVMDVI switch to run my PC and PS3 simultaneously. The PC view is working fine but when I switch to the PS3 I get a black & brown screen. (I know it is getting a signal because...
The SC switch is a Secure Switch for Goverment applications and or Military Ops, PS3 is therefore not a supported target. First of all because the Interface is most like HDMI owhich your switch doesn't support, the usage of adaptors are not going to work on that kind of switches.
I hope that helps.
Jan 15, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
No input signal on screen
that usually happens when your pc isn't turned on
Sep 25, 2009 | Acer Computers & Internet
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Emachine shows no signal when turned on black screen
check your cable from the monitor to the PC , make sure they are all fully connected and try again . please post what happens
Sep 15, 2008 | E-Machines eMachines Desktop PC
"No Signal"
go to safe mode then reinstalll or update dispaly driver . other wise set the screen refreh rate to 60 hz
Dec 04, 2007 | Acer AL1916B 19" LCD Monitor
Apex 51 inch projection model gb5108
I have worked on projection displays for about 17 years 20years electronic. and this sounds like a vertical deflection amplifier problem. this is if the lines or the rainbow you said that you see are horizantal.
Aug 03, 2007 | Sanyo DS24205 24" TV
Computers & Internet Logo
598 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
