Question about Samsung NV3 Digital Camera
Red eye and wise shot
In all manuals and reviwes there is an option to take a wise shot how can i do this and also how can i fix the red eye after shooting or before?
thanks for your help
Where is hold button ?
Posted on Apr 04, 2008
I can help with the red eye - I've had the camera a year now and have only just found it myself!! - After you've taken your shot, review the picture and then press the Hold button, press the right side of the menu button, just as you would when switching through your pics. In the blue menu bar at the top you will see the red eye 'paint' symbol, press down on the menu button and it will 'red eye fix.
Posted on Dec 27, 2007
Hi i m new at slr camera , i buy canon 500d , and when i take a shot , flash light twice or more before take the shot then flash be busy then take shot with flash did it a problem or what/
Check to see if you have the flash set on "red-eye". This causes the flash to pre-flash to eliminate red-eye in your photos. It's a real pain for most photos but if you're shooting in low light, it will eliminate the red-eye.
Feb 14, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Tip
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
on Mar 04, 2014 | Nikon Coolpix S4000 Digital Camera
Hi,, My Sony DCS-W100 flashes three times ,, how can i fix that?
This can easily be stopped, this is a feature used to reduce red eye, it can be stopped by turning off the red eye reduction option.
Jul 17, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Mytouch screen is messed up
it could have touched water or banged up, the only way to fix it is to ethire take apart the nintendo ds and get the screen and see a reviw to watch it, or ask the nintendo tech help and get them to fix it, other wise your nintendow ds lite screen is screwd
Jul 06, 2009 | Nintendo DS Lite Console
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Red Eye
There's two ways to reduce/eliminate the red-eye with your A570IS cameras. The first is at the time of exposure, by ensuring the red-eye reduction function is activated via the shooting menu (see page 28 of the manual). In shooting mode, press "menu", highlight the "tools" icon, and go down to "red-eye on/off". Toggle over to "on". That should take care of red-eye, in some, but not all cases. You can also remove red-eye after the image has been recorded (page 69 of the manual). You can isolate the red eyes if the camera doesn't automatically them for you. This should give you two shots at eliminating red-eyes. Another, often overlooked way to reduce red-eye is to zoom out and move physically closer to the subject, rather than relying on the zoom lens to get you close when shooting with flash. Hope this helps.
Apr 09, 2008 | Canon PowerShot A570 IS Digital Camera
Red eye
This camera is bad for red eye. It's just a problem that happens when the flash is so close to the lens. Red eye occurs when the flash illuminates the subject's retina.
The only solution, really, is to add an external flash that's farther away from the camera lens, which is not an option with this camera. The other, is to get better at taking photos without flash. Higher end cameras have better ways to deal with the red-eye, but these usually involve preflashes that close the subjects pupils (by blinding them with a preflash) before the actual exposure is taken. The Sony DSC-U30 has it as a feature, but it doesn't work very well, I've found. When it does work, it's a nice compromise as it gets rid of the red eye, but it also introduces a delay between pressing the exposure button and the actual taking of the photo.
Unless the light is very dim, I don't use flash with this camera.
After you've taken the photo and have downloaded it, there are ways to edit the red eye out that can be pretty effective.
Dec 24, 2007 | Sony Cyber-Shot DSC-U30 Digital Camera
Processing pause
Turn off the auto red eye removal option......you can manually remove red eye later. If the auto red eye removal is on, it will try and process each picture after you take it and slow down camera.
Dec 22, 2007 | HP Photosmart R927 Digital Camera
Turnning off red eye reduction option
go into the main menu by pressing the option or menu button then go all the way to the right and the 2nd or 3rd tab should have red eye reduction
Aug 12, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Samsung NV3 Digital Camera Logo
60 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
