Question about HP Photosmart 3310 Printer
On my HP Photosmart 3310 I recieve the error message "Memory Card Error". I cannot access the setup menu to reset to factory defaults.
Buschchris1
  • 474 Answers
SOURCE: Memory Card Error
If you can do so, go through the menu options and look for the ' restore to factory defaults option and do it.
Does it have memory ports to plug in or expand memory? if so, try turning off any optionsd to use expanded memory. Also, check the website, there maybe a simple soution available there.
Check for Firmware updates as well.
Posted on Feb 16, 2008
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
buffalonyman
  • 1865 Answers
SOURCE: HP Photosmart 3310 All in One - just failed
Go to the following link to get support for your printer
http://h10025.www1.hp.com/ewfrf/wc/product?product=439491&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Nov 05, 2009
Testimonial: "Straightforward answer & appropriate link!"
SOURCE: hp 3310 photosmart - ink system failure 0xc19a0013
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
If this doesn't work let me know.
Posted on Dec 20, 2009
Riztech
  • 731 Answers
SOURCE: error 0xc05d2281 what is this, please
These error codes indicate that the product has an internal error condition.
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges' message to display on the control panel.
  • Disconnect the power cord from the back of the product.Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Reply back; If the issue still exist.
Regards,
Riztech
Posted on May 02, 2010
Syster error, or please restart camera messages... lens seems to go a little berzerk... HELP! I love this camera...
Hi.
This sounds like the camera has developed a fault with the lens. You can however try to reset the camera to factory defaults.
Before you perform this action try and copy any data from the internal memory to the camera card (if you have one in) and then remove the camera card.
In the setup menu on the LCD display scroll to "Reset" that will return the camera to factory defaults.
Hope this helps and good luck.
Jun 09, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
My digicam lens keeps on moving... coming in and coming out and the screen says "ACCES"
The ACCESS error message displays when there is an internal malfunction or a malfunction with the Lens. This may also appear when accessing the Memory Stick for reading or writing the data. If the Lens is moving in and out then follow the steps mentioned below. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 19, 2011 | Sony CyberShot DSCS750 Digital Camera
I have a system failed error code Oxc19a0013
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord
Jul 10, 2010 | HP Photosmart 3310 Printer
I continue to get this error message on my HP A612.
first check the card to make sure it isn't write protected, if it isn't write protected, put the card into a camera and the camera should fix it
REF:
http://h10032.www1.hp.com/ctg/Manual/c00701123.pdf
Dec 25, 2009 | HP Photosmart A612 InkJet Printer
Error 000000c8-8be7-586-053
Please, perform a camera hard reset. To do so, follow the steps below:
  1. Turn off the camera.
  2. Remove any memory card installed.
  3. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  4. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
  5. Verify if the camera works without an optional memory card.
NOTE: Resetting the camera returns all settings to the factory defaults. Any images stored in memory will be retained. If the error message still appears after performing the camera hard reset, please click contact hp on this page for more support. CAUSE: The issue is caused by the Focus Home Sensor falling out of its position.
Nov 28, 2008 | HP Photosmart M22 Digital Camera
Nov 16, 2007 | HP Photosmart 3310 Printer
Keeps saying memory is full
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to error message  that " Memory is Full "  . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I guess that this could be your error message " Card full
or Memory full". The possible cause could be Insufficient room in internal memory or on the memory card to save more images. To resolve the issue please unload images from the camera to your computer, then delete all images from the memory card or internal memory. Or put a new memory card in the camera.
Please try to Power Reset the Camera once,  I hope this could work on AF flashing issue.
Steps are:
Resetting the camera can correct many issues, such as the camera locking up or not turning off. The reset drains the power and, in some cases, causes the camera settings to revert to factory defaults.
NOTE:
Resetting the camera returns all settings to the factory defaults. Any images or video clips stored in memory are retained.
Perform a power reset of the camera
Follow the instructions below to reset your HP Photosmart camera.
  1. Press and hold the Power button for 10 seconds.
  2. Release the Power button.
  3. Press the Power button to turn on the camera.
  4. When the camera turns on, you might be prompted to set the date and time.
NOTE:
When turning on the camera normally, press and immediately release the power button. If the power button is held for more than five seconds while turning on the camera, the camera might reset automatically while the lens is extending.
I found more information related to the AF Flashing that you are referring. Please open below link .
Link is :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00003782&cc=us&lc=en&dlc=en&product=90112&dlc=en&lang=en
Once if you open the link, please go through the information I guess that this should help you and will resolve the issue.
However, if the issue still persists then I recommend you to contact HP Support team on this issue. Because their expertise would help you better. For your convenience  I would like to provide a web link to contact HP Online Chat Technician.
Link is :
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=camera&productName=HP+Photosmart+735+Digital+Camera&productCategory=12117&SCOID=82642&PSOID=90111&lang=en&cc=us
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I
Oct 28, 2007 | HP Photosmart 735 Digital Camera
Memory Card Error
Oct 26, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
