Question about Home
I've got a wash cloth stuck in the sink disposal
I put the disposal on and a wash cloth had slipped into the drain. It is now stuck. Is there a way to release the blades and turn them in reverse/
  • 129 Answers
Yes, you will need to get a disposal wrench, one would have come with diposal new. If you cant find one, one can be bought at hardware store. On bottom of disposal in center you should see a hole, the wrench will fit there. Turn counter clockwise. This should free up wash cloth.
Posted on Sep 29, 2009
Testimonial: "I found the allen wrench opening and it did free the washcloth, but now the unit hums and is leaking. It seems to be leaking from the reset button."
Sink erator
First, unplug the power cord to the "Sink aerator" disposal from under the sink storage area. Next, remove the black rubber strainer from the upper sink area leading down into the disposal. (It simply pulls upward to remove) This will allow you to put your hand down into the disposal area to physically clean out the disposal deposits by hand. Pull out whatever is plugging the disposal and throw the debris in the trash, not back into the disposal. Once everything is removed from inside the disposal, flush it out completely with water from the faucet until it drains freely. Reassemble the black rubber strainer and plug in the disposal once clean. Be sure not to put potatoe peelings and other non-disposable items which can't be ground up easily in the garbage disposal. Keep in mind, just because it says garbage disposal, it doesn't mean all "garbage." Also, always use plenty of water when using the disposal and allow the water to run for a minute or so afterwards to finish washing down the debris in the sink "P" trap drain out through the outer sewer line.
Jul 07, 2014 | Home
Water does not drain from sink unless disposal is turned on and running. what could it be?
It would appear there is a blockage (a clog) in the disposal. You might try "FIRST" unplugging the disposal from under the sink. Put a piece of masking tape over the switch to secure it in the "OFF" position. Then remove the black rubber strainer from sink leading down into the disposal. (just pull it out by hand) Clean out all debris by hand. Put the removed debris in the trash can. Run hot water down into the disposal assuring it to drain properly. Do not put items into the disposal which cannot be ground up easily such as potato peelings and meat products.
Jun 24, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
The hose detached from the garbage disposal. I re-attached it and now the water can't pump out of the bottom of the dishwasher
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Jul 08, 2012 | Whirlpool Dishwashers
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
Odor coming from disposer
Hello, Tell your husband to wash his feet some place else, OK. it needs to be cleaned. Don't put you hand in it, OK. On the top in sink remove the rubber flapper and clean it with soap water and vingear. Put about four large cups of ice and tuirn on the disposer. The ice clean out any stuff that in the chopping blades. Mix up a sink of water, soda and a little clorex in the disposer sink then let the sink drain and turn on the gargage disposer then let it run while water is running into it. Do a cleaning procedure once or two a month. couple of lemons, Clorex, baking Soad, this stuff will work great. It will make you disposer smell like fresh spring day but tell you husband to keep his feet out of the kitchen sinks. GB...stewbison
Sep 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Disposal works, won't drain, other side of sink drains fine.
well if you put things like rice--chicken fat ==it will pass through the disposer but it will clugg your pipe so yes your pipe is clogged
open the j trup it might come out
Jan 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Home Logo
2,442 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
