it depend what year is it most bmw have anti theft on the and if take the off and don't have the codes you will have a problem,, so you might want get a cigarette lighter cord ( you can buy at a car battery or auto parts )that hooks up to 9 volt battery or a 12 v battery to keep the flow to the computer so it dosnt lock then take the battery out which is most likely under the back seat as i said it depends what year the car is ,,,,good luck ,,, Joe
Your battery is located in the trunk on the passenger side of the vehicle. To disconnect and remove the battery first remove the black plastic cover which houses the battery. Then disconnect the negative lead (black) followed by the red (positive) lead. Make sure the leads do not touch the battery while removing the battery. There is a small bracket located at the bottom of the battery box. This bracket holds the battery in place and can be removed by unbolting the 10mm bolt which holds it in place. Once this bolt is removed you can remove the metal bracket and lift the battery out of the bin. Installation is the exact reversal of this process.
Comments:
May 20, 2009
- The battery for your vehicle is located in the trunk on the passenger side. There is a black plastic cover which houses the battery. To remove the battery you must first remove this plastic cover. Unbolt the black (negative) lead and remove it from the battery. Next, unbolt and remove the red (positive) lead. Make sure the leads for the battery do not touch the battery throughout the rest of the removal process. There is a metal bracket at the bottom of the battery bin which keeps the battery in place. This must be removed by unbolting the 10mm bolt which holds the bracket in place. Once this is removed you can lift the battery out of the battery bin. Installation is the exact reversal of this procedure.
Was this helpful?
Yes
No
Popular Solutions for KitchenAid 325 Watts KSM5PS
KitchenAid 325 Watts KSM5PS Heavy Duty Stand Mixer
I have a KitchenAid KSM5PS series mixer that I picked up at a garage sale. No manual, but I did find...
(More)
I have a KitchenAid KSM5PS series mixer that I picked up at a garage sale. No manual, but I did find the manual online. I need to adjust the bowl to beater clearance, but the adjustment screw is not located where the manual says it should be. The area where the manual says the screw should be doesn't even look like the picture in the manual.
What am I missing?????
Dee
In my area small town in Costa Rica, I am the only one that does maintenance on kitchen aid mixers...
(More)
In my area small town in Costa Rica, I am the only one that does maintenance on kitchen aid mixers and there must be around 59 units of different years mostly KSM5 models but others a bit older Heavy Duty and some more. Need maintenance manual for this , how can I obtain same? Parts are available at the capital city Please advise on obtaining thr amnual or manuals.. Speed plates the same for all models?
We have Heavy Duty kitchen aid and will not pick up speed. Have changed brushes as they wear out to...
(More)
We have Heavy Duty kitchen aid and will not pick up speed. Have changed brushes as they wear out to fast. Rotor on brush end is worn out to a cone shape wear is more in end towards bearing. What do reccomend
