Question about Crest Audio CA9 Car Audio Amplifier
Clip and protect LEDs but no speaker output - Crest Audio CA9 Car Audio Amplifier
  • 58 Answers
Protect is a mode that it goes into that prevents future damage, i would recommend replacing the fuses.
Posted on Oct 24, 2009
Amplifier (now 8 years old) fails to power up. When pressing ON the input selection LEDs light but it sounds like the protection relay operates and there is no output.
It's possible that there's a short in the speaker crossover that has reduced the impedance below safe levels.
Otherwise, the relay/breaker might just need to be replaced.
Sep 21, 2015 | Audio Players & Recorders
Nad 7600 receiver
Power up without the speakers off, if the problem still exist, check output and driver transistors for leek or short.
Apr 03, 2014 | Audio Players & Recorders
Clip light is on volume is low
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers
Nov 30, 2011 | Kenwood VR-307 Receiver
No output on either speakers or headphone, input meters are permanently lit up all the way to the red 0dB LEDs (i.e. overload). I have tried direct USB input and the USB LED on device lights up and...
Ive just fixed 5 of these :D (for a studio)
All had the problem with the signal clip being lit up as soon as you plug it in.
I found on every one, the component U9 had failed! (after 6 hours of probing)thought id post this up as i couldn't find a fix any other place!Checked the service manual, U9 is a:IC VOLTAGE INVERTER CHARGE PUMP UNREG TPS60403 SOT23-5
got mine from:http://int.rsdelivers.com/product/texas-instruments/tps60403dbvt/tps60403-60ma-250khz-inverter-sot23-5/5171208.aspx
soldered it in and jobs a good'n
Jul 17, 2011 | Alesis iO | 2 Sound Card
The amp won't power up. The cord is is, the power is on, but when I press the Standby/On button, the MP3 LED blinks a few times, then it goes off and all the LEDs, from the protection, speaker A, B and so...
Hi... If all the speakers are connected properly then I would say, there is a failure in either the power supply filtering caps or one output has failed and it's going into Protect mode to keep from frying the speakers
It will require service at that point.
Aug 21, 2010 | Cambridge Audio Azur 650a 2Channel...
My peavy has three lights at power on when in use red light comes on is that beacuse my amp is overheating or is it normal it does that when i crank the volume amp i not hot well vented
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00512180.pdf Page8 sections 2 through 4 discusses the LEDs. I think what you arte talking about is the DDT active LEDs. Page 12 specifically discusses this and page 15 notes that Red signifies DDT clipping. Peavey recommends that you don't defeat the DDT circuit and that is good advice as it protects your amp and your speakers. The clipping is not caused by the amp but by the amount and quality of signal being input. Check earlier in your signal chain for the cause.
Aug 14, 2010 | Peavey Pv 2600 Power Amplifier
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
When i turn up the volume on my head unit my amp goes into protect mode or when i turn up the bass
You likely have a speaker with a swollen voice coil. Voice coil becomes hot due to under powered amp being clipped. Voice coils swells and rubbs. shoteing amp output causing amp to go into protect. replace speaker before amp is damaged. The more capacity an amp has wattage rating. the easier it is on speakers. Most speakers are damaged by underpowered amps being clipped rrather that too high of amp reting.
Apr 22, 2009 | Car Audio & Video
My amp automatically turns over to protect when powered
Disconnect all of the speakers and see if it does the same thing. If it does come on, you will need to check all of your speaker wire as well as the speakers. If it still goes into protect, I'm afraid to say that there is a short in one or more of the output or driver stages of the amp. Unless you know how to trouble shoot solid state printed circuit boards down to the component level, you will need to have the amp look at by a pro. Good Luck
Feb 15, 2008 | Blitz BZA2160 Car Audio Amplifier
Amp going into protect mode
If you set the gain too high on the AMP, at loud volume levels some clipping or distortion of the output signal will occur. Most amps have a Circuit inside that detects this clipping or distortion and applies protection to prevent damage to the speakers and the amp. It would help to know if you are driving the speakers with a Line level output or using the speaker output from your deck. There are many things that can cause an amp to go into protect mode, and knowing a little more about your setup will help to solve the problem.
Nov 07, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Crest Audio CA9 Car Audio Amplifier Logo
337 people viewed this question
Top Crest Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Crest Audio Car Audio and Video Expert? Answer questions, earn points and help others
