Look for a circular plug at the end of the motor,opposite the pump.if your unit has such a plug,pry it out and spray or squirt a small amount of oil into the 'well' to lubricate the bearing.older models had a small hole on top labeled ''oil here''
something is gettn on belt-liquid etc-------make sure the pulleys are clean-the ribs collect dirt----the fan belt tensioner nay b goin out-its the single wheel-berrings wear
Possible there is dirt in the drain which seems to clog on the drain pump /valve and so when the drain cycle is activated the pressure makes the noise on the pump.
Check for tips to remove the Pump;
Before you junk it, double check to make sure steady shot wasn't turned off. Also see if raising the ISO settings and increasing the aperture size fixes the motion blur (this will make image noise and depth of view blur increase though). Lastly Try resetting the camera to factory settings as a last resort.
cam sensor will make a squealing noise i have an 05 freestar 4.2l take the top of the sensor off put 2 drops of motor oil in it and reassemble that will take care of your noise .
