Question about Brother MFC 240C All-In-One InkJet Printer
Brother mfc 240c prints but scanner not recognized under photoshop, etc
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
Posted on May 31, 2008
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc 240c error says print unable 51
Hi Ok try this it may work.
Hapens a lot
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Posted on Mar 02, 2010
Jimsta01
  • 405 Answers
SOURCE: Brother mfc-240c doesn't recognize ink cartridges
It may be a memory issue.
Unplug the machine from the power.
Remove all the ink cartridges
Replug the machine and reinstall the ink cartridges
Posted on Mar 27, 2010
My brother mc 240c print in yellow but not black? It connected to my laptop throw usb connection.
Clean the print heads and then make sure the drivers you installed recognize all of the ink cartridges ar their proper ink levels. Replace ink if necessary.
Aug 24, 2011 | Brother Multi-Function Center MFC-240C...
Where is the usb port to plug in the printer Brother MFC -240C
It is located under the scanner cover, under the glass, if you look at the right side of the machine there is a groove to place your figer to completely open the cover, the USB cable would be located on the right side.
Jul 13, 2010 | Brother Multi-Function Center MFC-240C...
How to scan on a brother MFC-240C printer?
Use your paint program under accessories.
Start - accessories - paint - file - from scanner or camera - choose your device and follow the directions
May 28, 2010 | Brother Multi-Function Center MFC-240C...
Brothers MFC-240C not printing in color???
Do you have it set to print in black and white as the default? Go into the print driver, under Color Management, and select Color.
May 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer unable 4F-what does this mean?
If still under warranty, I would call Brother for an RMA (return merchandise authorization) code and return the product. Why fiddle with it?
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
How to change to a higher resolution on a mfc-240c
Hi tammy, you can either use the Windows printer driver which will allow you to set scanning resolution up to 1200 dpi which you can access through a program like Photoshop (File--Import) or the Brother Scanner Utility to go up to 19200 dpi resolution. If for some reason you don't have the scanner utility on your computer, you may have to install it from the disc that came with MFC-240. If you need further help let me know.
Oct 23, 2008 | Brother Multi-Function Center MFC-240C...
Will not print
go to brother.com website under drivers support download latest driver should fix the issue ok download it then install it
Oct 12, 2008 | Brother Multi-Function Center MFC-240C...
Sacnning
REINSTALL SOFTWARE AND ALLOW IT TO FINISH
Jun 02, 2008 | Brother MFC 240C All-In-One InkJet Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
129 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
