Question about Video Cameras
Sony DVD92 LCD/Viewfinder doesn't display image
Images will not display on the lcd panel or through the viewfinder. If I try to record anything I get the sound but no picture durring playback. Any ideas?
  • 1 more comment
  • Keesenat Jan 02, 2008
    I can plug my camcorder into the TV and it will play the video but when I try to play it on the camcorder its self there is sound but no picture......WHY?
  • JLAZ Jul 28, 2008
    i have the sony handycam dcr-dvd100 and when i turn it on i cant see anything through the view finder or lcd screen. it records sound but no picture.
  • Anonymous Nov 23, 2008
    I have exact same prob.
I had this problem and called Sony. Apparently there was a problem with handy cams and they paid to fix it.
Posted on Feb 09, 2010
The LCD monitor displays taken images but isn't operating as a viewfinder.
The XT does not have 'live view' - you can only use the LCD to view taken images
Mar 23, 2013 | Canon Rebel XT / EOS 350D Digital Camera
No display in viewfinder and LCD
i think you are able too see the video in play back mode. so there is no problem in your LCD.
i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode.
because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
Dec 25, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Pentax K200D NO LCD just viewfinder visual
Pentax K200D is a SLR Digital Camera..... in SLR you can the images in LCD after it has been taken.... while cliking image you need to use the Viewfinder......
Mar 24, 2009 | Pentax K200D Body only Digital Camera
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
the LCD.
four.
Hope this solution helps you a lot
Please rate me on the above said solution
Feb 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
LCD monitor and electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
LCD Monitor on and the electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Video Cameras Logo
283 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
