Question about Kenmore Elite 45986 Front Load Washer
How do I remove the back panel off Kenmore Elite Dryer
  • 15,935 Answers
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
How to remove back panel on a kenmore elite gas dryer
Should just have 3 screws down each side and 2 or 3 across the panel on the back of the dryer.
Jul 22, 2015 | Kenmore Dryers
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
How do I find the Kenmore dryer model number, if I do not have the owner's manual?
There should be a sticker on the back and/or another on the inside of the back panel or on the door.
Kenmore Elite 23012 Washer and Kenmore Elite 63942 Dryer
Jan 25, 2010 | Kenmore 63942 Dryer
My Kenmore Elite 63952 have to hold down start.
yes switch is bad u will see on very back of machine they are a acess panel on very top of the back may 6 to 8 screws take them out remove acess panel off then un plug the the switch u should see how to remove the switch......make sur u un plug the machine before taking it apart
Oct 23, 2009 | Kenmore 63952 Electric Dryer
Either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Mar 28, 2009 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore Elite Dryer Blower fan is loose
in the back opf your dryer the drum runs on 2 black rubber wheels when they are worn out it will giveyou that kind of noise replace them they cost about 8.00 each there is two of them you van see one from the bottom right side in the back of the drum if you remove the front lower panel thanks from gilles
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
How do I remove the bottom panel from the Kenmore Elite Quiet Pak II dryer? I need to vent the dryer from the bottom rather than from the back of the unit.
hi. thanks for the question . 2 screws on the bottom of the front panel .remove these screws . pull on panel, lift from bottom . thanks the appliance doc. please rate this answer. thanks the appliance doc
Oct 01, 2008 | Kenmore Dryers
Kenmore Elite 45986 Front Load Washer Logo
243 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
