Question about Whirlpool GGQ8831L Gas Dryer
Dryer wouldn't heat, replaced ignitor, was fine but now smell gas.....can't find any leaks in pipes
I can't smell gas in mine. The igniter sparks but does not light up???
Posted on Sep 26, 2009
Hi, i have a maytag dryer( model mdg7600aww). It works fine but every time that i use it, it smells like gas. i checked all the gas lines and found no leaks. is there something else that can cause it to...
Yes... when the ignitor gets weak and does not work right you can also get the gas smell...change the ignitor and the gas smell will go away because the ignition will be better and smoother...
heatman101
Sep 05, 2011 | Maytag MDG7600AW Gas Dryer
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Cloths are not drying and it smells like gas in dryer (gas dryer and no gas leaks)
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 14, 2010 | Kenmore Dryers
No heat gas smell
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Mar 08, 2010 | Estate EGD4400SQ Gas Dryer
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
Nov 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
