Question about JVC KD-G110 CD Player
Where do you plug in antenna - JVC KD-G110 CD Player
  • 54 Answers
There is a hole in the back it has a metal shell stick the antena in the hole if it don't fit then go to walmart and buy an adapter
Posted on Sep 27, 2009
Repair radio antenna plug
Radio shach has a solderless antenna plug(but it is a generic type).You will probably have to get this plug and a GM adapter.(GM is the ONLY AUTO MANUFACTURER that doesn't use an antenna plug like the rest.
Dec 06, 2012 | 2006 Pontiac Sunfire
On 2000 monte carlo is the stereo antenna powered?
when you turn on the radio or the key with the radio on if the antenna goes up its a power antenna,if this is not what you mean then the antenna is not powered as we think of power.it collects radio air waves and sends then to the radio and there is a ground on the antenna were the antenna plugs into the back of the radio.you could have a poor connection were the antenna plugs into the radio.
Apr 21, 2011 | 2000 Chevrolet Monte Carlo
Cant get radio to play stops on station wont pick up antaina hooked up
Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
Jan 30, 2011 | Sony Car Audio & Video
I have a Garmin 3600. When I want to use the GPS feature, and I open the antenna, all I get is Acquiring Satellites, but nothing happens (the little indicatior on the bottom shows activity). I thinkthere...
If you can obtain an external antenna from another IQ3600 user it
will plug into the connecter on the top of the unit and bypass the fold out antenna. I had to buy one because the windshield in my Pont Montanna would block the satalite signals. When I plug in the external antenna I do not have to fold out the antenna on the unit.
That will check to see if the unit is recieving and /or if the fold out
wire is broken. The external antenna is not Garmin specific but the
plug on the end is so another gps antenna with the same end plug works.
Aug 16, 2010 | Garmin iQue 3600 GPS Receiver
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Unit does not pick up satellites but recognizes when antenna is open
I have a unit like that. The antenna appears to be dead. It just searches forever and never finds anything. I use an external antenna that I got from eBay (brand is Gilsson) and it works fine. You just plug it in the external jack (after removing the little rubber plug) and it works even better than the built-in antenna.
Jul 01, 2009 | Garmin iQue 3600 GPS Receiver
Sirius Antenna
There are several ways to tackle this problem, most of which would involve getting to the back of the radio, but before you do, make sure you have an "antenna extension cable". Then plug in the 'extension cable to the radio/sirius unit' leaving the other end to 'hang out' where you can then get access to the 'extension' cable. Then you can plug in the existing antenna when you're not using the camper or plug in new antenna that gets clear view of the satellite. Depending on your location and general direction of travel you may be able to use a 'home unit ' antenna on your dash as I do and it works very well. In my truck I often use a home antenna also, although I also have the large unit that bolts to the (tractor) truck mirror assembly.
The other solution is to find a CB repair place (often at truck stops) that is familiar with repairing, satelite antenna wire and pucks. Have them split the wire and place a male and female plug to accomodate the extisting antenna and the new antenna. This service will cost you about $30-50.00 They should find the parts needed at a satellite radio store that sells marine/business/home antennae systems. The parts are not all that common - or the CB fellow may connect male/female connectors that are unique to your truck situation - then any connectors will work but only on that truck of yours. -- Frank
Sep 15, 2008 | Audio Players & Recorders
Replace window antenna with real on on a 2005 Civic EX.
You will have to disconnect the window antenna lead from the back of the radio and plug in a fender mounted antenna lead cable into the radio.
Jun 08, 2008 | 2005 Honda Civic
JVC KD-G110 CD Player Logo
44 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
