Question about HP DeskJet 5150 InkJet Printer
Vista. How to setup to Print with Black Ink Only.
Vista. How to setup to Print with Black Ink Only. It currently always prints with a grey scale using colour inks. Was not an issue with XP.
  • 82 Answers
SOURCE: hp officejet 5610 how to select black ink printing only
Start, Printers and faxes, Right-click your printer - Properties, Printing preferences, Advanced, Print in grayscale - Black only...
Posted on Nov 16, 2007
SOURCE: D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Posted on Jul 19, 2008
terrilinda
  • 73 Answers
SOURCE: Greyscale Printing
Go into Printers, Properties, Printing Preferences, then Black Ink Only. If you make that the default, it will automatically print black ink with you click on the printer in the toolbar. If you want to print one document in color, click on File, Print, Properties, and set it for color for that one job only. The default of Black Ink should stay the same.
Posted on Sep 12, 2008
SOURCE: black ink does not print
i had the same problem. black stopped printing. i always used OFFICIAL HP cardridges, so this problem is not exclusive for refilled cardridges.
This solution (offered here) worked for me:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
I wanted to stress that you should make sure that:
1) you keep the the buttons down untill it shuts off;
2) on restart you get a notification of service;
3) to turn it off again after service before you turn it on for actual use.
Posted on Jan 11, 2009
SOURCE: Want to print in color ink and not black ink.
These instructions are for Windows Vista users - I've never used XP to do this, but I'm sure it's similar.
Go to Control Panel/Printers and select the printer you want. Click "Select printing preferences" on the toolbar above. The options listed might be different for different printers (I haven't checked) but on my Dell printer I go to Advanced/More Options and under the "Complete-a-Print" section there is a checkbox labeled "Use color cartridge for all black printing." I imagine other printers have something similar. It comes out a dark grey/brown color.
Don't forget to uncheck it when you get more black ink!
Posted on Feb 18, 2009
When I try to print in grey scale on my HP 8150, it starts out in grey, then switches to a purple-blue with grey scale stripes in it. This is a new problem with this printer, which has always been great. ...
i think there will be also one option use only black cartridge
that will solve ur problem
actually when it print in gray it uses all colour and then print in gray
Aug 07, 2013 | HP Photosmart 8150 InkJet Printer
I can't print in grayscale with my colour cartridges
The black ink cartridge is used to print in grey scale mode.
It is therefore not possible to print in grey scale using only colour ink cartridge.
damnor01
Apr 11, 2011 | Dell 810 All-In-One InkJet Printer
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
Printer is only printing grayscale, need color, hp deskjet 6340
This is either because: 1. You only have black ink remaining and your tri-colour cartridge is empty or 2. In the printer driver settings you have selected either: Print Grey scale or Use black only.
I beleive your problem might be the last option.
To fix it :
1. Go to the printer driver (in vista go to: Start, Control panel, Printers, right click on your printer and select "printing preferences"). Now you are inside the printer driver. 2. go to the "color" tab. 3. Tehre you'll see if you have selected wither "Print in grey scale" and/or "Black only". 4. To ensure you get color again, de-select the"Print in grey scale" option.
Cheers, Ed
Oct 04, 2009 | HP Deskjet 6940 InkJet Printer
Black ink only
go into control panel click on your printer go into properties preferences click on grey scale
Jul 30, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Greyscale Printing
Jul 26, 2008 | Epson Stylus CX5000 InkJet Photo Printer
HP deskjet printer D2460
Welcome to Fixya !
I assume that the printer is set to print in grey scale as below. follow the same procedure to change it to colour mode. If its still priniting in the Grey scale mode, Then please check the ink level in the printer.
Print in grayscale
To print in grayscale
1. Open the Printer Properties dialog box.
2. Click the Color tab.
3. Click Print In Grayscale.
4. In the Print In Grayscale drop-down list, select an option.
5. Select any other print settings that you want, and then click OK.
Apr 03, 2008 | HP Deskjet 2460 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
