Question about Bladez Ion 9.9 Fold-up Treadmill
The display won't light up
I was on my treadmill today & it tripped a breaker and the power went off. When I reset the breaker now my treadmill turns on but the display won't light up.
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Could this be a power surge?
More likely power went off line and when came back tripped the breaker......
Apr 18, 2012 | Televison & Video
A2550 no power at all
Dear Sir:
1)Most probably you did short circuit.
2) Test the fuse or breaker inside.
3) Check if you breaker from your house or building is tripped, since there are No power Must be 90% that your breaker in your building is tripped.Re-started again.
4) Test again the treadmill, and will be working
Of course when you open for to see the fuse or breaker, see if there are something with smell to burn. If there are burn, you must to Test it.
Finally you must not used extension cords. Use directly to outlet with connection to ground +device for power transient+100% stabilizer of voltage.
sincerely.
Nov 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Pro form 365 won't start
Dear Sir:
I will help you, please do the exact step:
PROBLEM: The power does not turn on
SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
Finally: check, the breaker from the home, if there tripped, check this, and Reset.
I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
Thank you in advance, sincerely.
Blessing, if you need additional help, please contact me.
E.CUADRA MANAGUA, NICARAGUA.
Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
I have two cardio zone treadmills which won't start. console lights but nothing happens. checked the two fuses for continuity, both good. what else can i check? s/n 35005624 and 35005616
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Sep 13, 2011 | Cardiozone Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
May 17, 2010 | Weslo Cadence Ct 5.8 Treadmill
Will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Apr 30, 2010 | RTO Lifespan Fitness Tr 2000 Hrc Treadmill
I left the red key in epic view 550 for 1 full day, next day when discovered now treadmill will not start, no lights, no noise, nothing!! Help
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Apr 30, 2010 | Epic View 550 Treadmill
We had a thunderstorm last night and power blinked for a second or two, but never went off for any amount of time. Later, I discovered that a couple of my breakers were tripped (sockets & lights) and I...
Hi There,
It certainly seems like you got a large power surge. Something may have been fried on your oven control panel. The trouble is circuit breakers are meant to trip when there is an overload or short circuit situation. Good ones will also detect an earth leakage problem to save us humans from being electrocuted.
Unfortunately in general they are not surge protectors. That is they will not trip quick enough to save your appliances if 10 zillion volts suddenly comes down the wire.
I think you are going to need a service technician for this one.
Good luck
Doug.
Aug 06, 2009 | Kitchen Ranges
Bladez Ion 9.9 Fold-up Treadmill Logo
32 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
greg kinsley
Jamie Miller
Jamie Miller
Level 1 Expert
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
